1. pst23's Avatar
    First things first the fact that I can not a decent screen protector is taking the enjoyment out of this phone. Also I had the zagg hd dry and clear and they both got messed up once I put different cases on the phone.
    03-12-2016 10:53 AM
  2. srkmagnus's Avatar
    It might be an issue with certain cases and/or screen protectors. Hopefully it's not a problem for all.
    03-12-2016 11:24 AM
  3. bsteppuhn's Avatar
    I didn't have a problem with my case or screen protector
    03-12-2016 12:37 PM
  4. felloffthetruck's Avatar
    And what screen protector is that?
    03-12-2016 12:40 PM
  5. Lobwedgephil's Avatar
    Did you give it 24 hours to dry? Using Zagg HD with Luvitt Clear case, no issues.
    03-12-2016 12:53 PM
  6. bsteppuhn's Avatar
    I see its unavailable now in the reviews they talked about bad cut outs. Mine a lines perfectly
    Attached Thumbnails S7 Edge screen protector messes up after putting on case-123.jpg
    felloffthetruck likes this.
    03-12-2016 01:27 PM
  7. skhalid93's Avatar
    It's an issue with your case and/or screen protector overlapping the screen's edges. 95% of cases are manufactured to be flawless with the phone, and with a screen protector you add .1/.2 whatever to your screen, which interrupts the seamless design. I have a case on my s7 edge and also have a zagg shield on it. Have had it for 2 days now with that setup and it is perfectly fine.
    03-12-2016 04:07 PM
  8. Leslie Hatcher's Avatar
    Skinomi had issues with their screen protector, so they sent me a free replacement. But it works fine, just needs the time to dry completely, and set up.
    03-12-2016 05:32 PM
  9. Tarah Sorber's Avatar
    I have the Zang HD dry on my s7 edge. Most cases did mess it up, but after trying on like 6 in best buy it finally found one that didn't mess it up. It's the clear speck case.
    03-12-2016 08:51 PM
  10. snyderhawkeye's Avatar
    I just got the zagg hdx and the spigen tough armor. When I put the case on, the corners of the zagg started lifting. Never had this happen before.
    I'm getting a new zagg for other issues (debris on sticky side when it came out of the box), but don't want out to happen with next one when it arrives
    08-14-2016 09:02 AM
  11. briannamarie91's Avatar
    I am using the armor suit case friendly one and its working great so far
    08-14-2016 10:19 AM
  12. underway99's Avatar
    I'm using the Zagg HD with both a Spigen Neo-Hybrid Crystal TPU case and an Otterbox Commuter. No corners coming up or anything else after a month.
    08-14-2016 11:59 AM
  13. arif1990's Avatar
    which case and screen protector u use...plz suggest me
    08-16-2016 03:23 AM
  14. briannamarie91's Avatar
    On Amazon search "case friendly" s7 edge screen protector. There are many. I'm currently using the skiniomi one
    08-22-2016 10:00 AM
  1. S7 Edge Rattle
    By ak89uk in forum Samsung Galaxy S7 edge
    Last Post: 11-08-2016, 11:52 AM
  2. Unlocked AT&T Samsung Galaxy S7 - w/ Speck Case!
    By rockitdog23 in forum Marketplace Archive
    Last Post: 03-26-2016, 05:52 PM
  3. verizon preorders for silver s7 edge after 3/1
    By chopchop17 in forum Samsung Galaxy S7 edge
    Last Post: 03-12-2016, 05:27 PM
  4. From iMessage to s7 edge
    By uawildcat in forum Samsung Galaxy S7 edge
    Last Post: 03-12-2016, 11:40 AM
  5. My Alcatel Pop C7 doesn't turn on
    Last Post: 03-12-2016, 10:59 AM
