1. ak89uk's Avatar
    Hi guys
    When you shake your phone do you hear a slight rattle?
    Just wanted to know if this was normal before I send it back!
    Interestingly when the camera is on, the rattle appears to subside?
    03-12-2016 10:09 AM
  2. dpham00's Avatar
    no rattling on mine
    03-12-2016 10:16 AM
  3. ak89uk's Avatar
    Cheers, didn't think there should be!
    03-12-2016 10:18 AM
  4. Andyvalver's Avatar
    If it does rattle it will be the optical image stabilisation in the camera. It's supposed to float about.
    Posted via S7 edge 😍
    03-12-2016 10:21 AM
  5. bhatech's Avatar
    This rattle thing thread sure shows up for every device ☺
    Andyvalver likes this.
    03-12-2016 10:23 AM
  6. ak89uk's Avatar
    So does this mean its normal or faulty?!
    03-12-2016 10:39 AM
  7. Andyvalver's Avatar
    If it's the camera it will be normal.
    03-12-2016 10:58 AM
  8. ak89uk's Avatar
    Yep it disappears when the camera is on...
    03-12-2016 11:04 AM
  9. Miniscous's Avatar
    Yeah dude is rattling toooo. And it stops when the cameras on. Did you look into it anymore or is everything sweet?
    09-18-2016 05:39 PM
  10. anroid101's Avatar
    Its the focus lens on the camera
    11-06-2016 05:30 PM
  11. patstar5's Avatar
    I thought my phone was broken for a minute. I just noticed it. I got mine off of ebay for $500 back in July. Yep, if the back camera is on then it stops.
    11-08-2016 10:29 AM
  12. Tsepz_GP's Avatar
    Its the camera, phones have had that rattle since Auto Focus was put into them.
    11-08-2016 10:49 AM
  13. Fit24's Avatar
    I don't hear any rattling on mine.
    11-08-2016 10:52 AM
  1. Changing fonts on s7 edge/marshmallow
    By Slpsht19 in forum Samsung Galaxy S7 edge
    Last Post: 12-15-2016, 12:08 PM
  2. Unlocked AT&T Samsung Galaxy S7 - w/ Speck Case!
    By rockitdog23 in forum Marketplace Archive
    Last Post: 03-26-2016, 04:52 PM
  3. Replies: 4
    Last Post: 03-15-2016, 05:38 PM
  4. verizon preorders for silver s7 edge after 3/1
    By chopchop17 in forum Samsung Galaxy S7 edge
    Last Post: 03-12-2016, 04:27 PM
  5. From iMessage to s7 edge
    By uawildcat in forum Samsung Galaxy S7 edge
    Last Post: 03-12-2016, 10:40 AM
