08-09-2017 01:22 AM
694 ... 1213141516 ...
tools
  1. Coleboy23's Avatar
    I found a fix for my phone so far. I have a T-Mobile S7 Edge and I tried some of the things in the thread with no solution. Then I decided to take the SD card out of my phone without ejecting it while my phone was on then I reinserted it. I haven't had a notification since yesterday which is when I tried it.
    Edit: never mind it popped up again.
    04-04-2016 12:03 PM
  2. Devendra95's Avatar
    https://uploads.tapatalk-cdn.com/2016...5832493035.jpg
    Just received this update from T-Mobile. Hopefully this fixes the issue. I will report back
    UPDATE: the notifications are back, although with different wording. Instead of "SD card for transferring media files" it now says "tap here to transfer media files"
    04-04-2016 12:06 PM
  3. Devendra95's Avatar
    I'll give that a try. Did you receive the update today?
    04-04-2016 12:07 PM
  4. Wildo6882's Avatar
    Do they show up all the time or just on reboot?
    04-04-2016 12:07 PM
  5. Devendra95's Avatar
    They show up all the time
    04-04-2016 12:07 PM
  6. Wildo6882's Avatar
    Ugh. Man I want this phone but hate this issue and am slightly afraid of this issue.
    04-04-2016 12:11 PM
  7. Devendra95's Avatar
    I thought my T-Mobile update would have fixed this. Another user on this thread reported that the sprint update fixed it
    04-04-2016 12:27 PM
  8. ogio's Avatar
    i installed 'sd card monitor' a couple days ago, and here is an example of whats going on.
    04-04-2016 02:12 PM
  9. Coleboy23's Avatar
    Yeah I have it downloaded now I need to install it also the notification just popped up lol mine didn't work.
    04-04-2016 02:21 PM
  10. Coleboy23's Avatar
    Ok I got the T-Mobile update the issue still happens
    Devendra95 likes this.
    04-04-2016 03:34 PM
  11. Devendra95's Avatar
    This is getting ridiculous. I listened to music for 1 hour while coming home with no issues. Came home, set the phone down to eat a snack and there is the notifications again
    04-04-2016 05:44 PM
  12. Wildo6882's Avatar
    Have you tried doing a return? It seems like some people have had some luck on an exchange.
    04-04-2016 06:02 PM
  13. Devendra95's Avatar
    I might as well do that and get a different phone or go back to my s5
    04-04-2016 06:24 PM
  14. Wildo6882's Avatar
    If the one I get has issues I'm going to exchange it and if it keeps having issues I'll end up getting a different phone.
    04-04-2016 06:26 PM
  15. Devendra95's Avatar
    I'm willing to see the next lineup of Nexus phones. I think my next phone will be a Nexus since most of the Android features from other companies are becoming part of stock android
    04-04-2016 06:35 PM
  16. scott_0's Avatar
    I used to only get the notification after a reboot or power on, I no longer get it at all now, using a Samsung 64g Pro+
    04-04-2016 06:46 PM
  17. NexusGirlX's Avatar
    You should get it after rebooting or powering on the phone. That is completely normal and it's sort of a verification that the SD card has been read at start up.
    04-04-2016 06:55 PM
  18. TitanSK1's Avatar
    My replacement phone has no card notification issues, and is great. I suspect it's a small batch issue and chances are you will get a good one! Good luck!
    Wildo6882 likes this.
    04-04-2016 09:17 PM
  19. Devendra95's Avatar
    I backed up my SD card files to my computer just in case it decides to corrupt my data from the constant unmounting
    04-04-2016 09:29 PM
  20. DeerFilm's Avatar
    I was one of the first to get my S7 edge through the mail with At&t. anyone have an idea if there is a chance I can return my phone for a newer one?
    And please if someone finds a 100% cure for this to make a new thread.
    04-04-2016 09:43 PM
  21. felloffthetruck's Avatar
    Just picked up a brand new black S7 edge this afternoon. I'll put a new SD card in tomorrow morning and report back.
    Should I format the card in the phone or on a PC first?
    04-04-2016 10:00 PM
  22. NexusGirlX's Avatar
    I never formatted my Samsung Evo card. I just put it in my phone and started using it.
    04-04-2016 10:02 PM
  23. felloffthetruck's Avatar
    And you don't have the SD card notification pop up?
    04-04-2016 10:16 PM
  24. NexusGirlX's Avatar
    I don't have that notification that pops up for others in this thread on either one of my silver S7 Edge phones. I only have the one that shows after rebooting the phone and that is normal to have.
    04-04-2016 10:18 PM
  25. Wildo6882's Avatar
    Definitely let us know. I should be getting mine on Thursday so I'll chime in over the weekend then too.
    04-04-2016 10:35 PM
  1. S7 Edge screen protector messes up after putting on case
    By pst23 in forum Samsung Galaxy S7 edge
    Last Post: 08-22-2016, 09:00 AM
  2. Hopefully you guys can help me out - WiFi issues
    By say anything in forum Samsung Galaxy S7 edge
    Last Post: 03-13-2016, 09:18 AM
  3. Replies: 0
    Last Post: 03-12-2016, 11:20 AM
  4. Replies: 0
    Last Post: 03-12-2016, 11:03 AM
  5. My Alcatel Pop C7 doesn't turn on
    Last Post: 03-12-2016, 09:59 AM
