08-09-2017 01:22 AM
694 ... 1516171819 ...
tools
  1. Wildo6882's Avatar
    No dice.....the SD card unmounted on its own on the new phone WITH Good Lock installed. Out of the three cards we have, this is the only one giving us trouble. I'm just gonna have to put this behind us; can't spend anymore time on it.
    Man. That sucks. This is seriously a much bigger deal than anyone other than this thread is making it out to be.
    04-08-2016 08:06 AM
  2. Devendra95's Avatar
    Which SD card were you using?
    04-08-2016 08:36 AM
  3. felloffthetruck's Avatar
    Our new black S7 edge has only popped the SD notification twice in the past 3 days. A little better then the launch S7 edges but still a problem. I'm using a Samsung 128GB Pro + card in this phone.
    04-08-2016 09:32 AM
  4. mikef91's Avatar
    Just got off the phone with T-Mobile and they are sending me a new device. Fingers crossed. Hope this one works. Samsung support is terrible.
    felloffthetruck likes this.
    04-08-2016 12:58 PM
  5. asd6845's Avatar
    Ever since I downloaded the update from Sprint, no issues. That was 2 days ago. Got a SanDisk Ultra 64 in the phone now. Gonna try swapping the SD card this weekend to see how it works.
    OK, turns out the phone doesn't like PNY and favors the SanDisk Ultra. Weird. At least the SanDisk is running trouble free (knocking on wood).
    04-08-2016 02:52 PM
  6. Coleboy23's Avatar
    My S7 doesn't like PNY, Samsung, or Sandisk cards. I installed good lock and I haven't gotten the notification yet. Although I'm still skeptical because some people said good lock didn't work but it has been working for almost a day so far.
    04-08-2016 04:39 PM
  7. Alpha Male PR's Avatar
    I had the sd card constant notification on my phone, I tried everything including a phone exchange. I went to a Samsung representative at Best Buy, she erased android from my phone and reinstall a new copy ... THE PROBLEM IS GONE!!!!!!!!
    hillybillycrash likes this.
    04-08-2016 04:54 PM
  8. Wildo6882's Avatar
    Report back in a few days. A lot of people are saying that it goes away and then comes back.
    04-08-2016 04:56 PM
  9. hillybillycrash's Avatar
    I have watching this thread for a week to find solution for SD card keep Unmounting Itself on my Galaxy S7. Because my sd card pop up like hell (30-40 per day). Then I found the solution is I go to Samsung Galaxy app store to download an app call Good Lock. After install and restart my device, I don't get any more SD card unmounted pop up since Tuesday. I hope it helps you guys.
    Note: Good Lock is an app that update the Android system UI, so I think The Sd Card was conflict with System UI whole time.
    Didn't gind the app on galaxy store but a quick google search of samsung good lock found an apk download.
    Installed and will update in a day or two if the notifications and reboots stop.
    04-08-2016 05:40 PM
  10. hillybillycrash's Avatar
    Damn. Not good news.
    04-08-2016 05:45 PM
  11. felloffthetruck's Avatar
    New Black s7 edge just pop it's daily SD notification. I'm going to throw in the Sandisk 200GB tomorrow and see If I still get the pop ups.
    04-08-2016 08:38 PM
  12. Viet9a3's Avatar
    I'm sorry for what I've heard. I using the Good Lock App since Tuesday and I only got one Sd pop up when I restart my S7. I using the Transcend 32 GB MicroSDHC Class 10 UHS-I/U3 for my S7 (http://www.amazon.com/Transcend-Micr...cUvbUpU5113822).
    04-08-2016 09:53 PM
  13. Viet9a3's Avatar
    I'm sorry for what I've heard. I'm using the Good Lock app since Tuesday and I only got one Sd pop up when I restart my S7. I'm using Transcend 32 GB MicroSDHC Class 10 UHS-I/U3.
    Note: before I use Good Lock app. I had tried all solution on Internet to get away the SD pop up bugs such as: factory phone, format sd card by computer and phone, deselect System UI from Optimize battery usage, tried 3 differences micro sd cards, and more.
    04-08-2016 10:07 PM
  14. The Phantom of Columbus's Avatar
    I found this solution on xda...
    Format your SD card (after removing any personal files of course) and swipe the notice left or right, then open up the camera app. Make sure the app is set to save to the memory card. Take a 25-30 second video and view it.
    That solved it for me. A restart of the phone and the notice did not reappear.
    04-08-2016 10:46 PM
  15. jeetu4444's Avatar
    Well I just made the jump and brought S7 edge gold color...even here in india stock is sold out at most places...
    Thou i waited for new batch...and luckily my phone shows manufacturing date for April 2016...hope samsung has fixed the bug...
    Posted via My Awesome Lumia 950 ds red and gold or LG G4 or surface pro 4
    04-09-2016 09:04 AM
  16. hillybillycrash's Avatar
    Installed Good Lock from an apk download. Installed and formatted my Sandisk Extreme Pro 64 gb sdxc card last night. I still get the sd card notification but only on a reboot.
    The good news is I have only had one random reboot since last night.
    Fingers crossed
    04-09-2016 04:42 PM
  17. ogio's Avatar
    you guys need to quit wasting time reformating and hoping and whatnot. just go to your carrier and do a warranty claim.
    Roque13 and Sammuel1973 like this.
    04-09-2016 05:05 PM
  18. kappatau808's Avatar
    replaced my S7 edge. got it yesterday and so far no sd card notification
    04-09-2016 07:03 PM
  19. Alpha Male PR's Avatar
    This is a software problem, the bug is in the copy of android that was installed in the factory. You need to install a fresh copy of android through a Samsung representative or exchange your phone. Exchanging your phone does not guarantee that you wont get a phone with the same problem.
    Wildo6882 likes this.
    04-10-2016 09:05 AM
  20. Wildo6882's Avatar
    Are the reps at Best Buy aware of this? Can they do that there in the Samsung experience shops?
    04-10-2016 09:14 AM
  21. Alpha Male PR's Avatar
    The reps are not aware of this.
    04-10-2016 09:34 AM
  22. Alpha Male PR's Avatar
    I did it in a Best Buy Samsung experience shop.
    04-10-2016 09:37 AM
  23. Trees's Avatar
    Sounds like maybe a factory debug switch or value was left ON, or set to check for SD card access/availability for factory burn-in and QA testing? Maybe somehow that factory only build was released or the SD card check feature was not set to OFF prior to shipping the phones?
    I could be reading too much into the tidbit about the factory Android OS version, though. Could be another dead end hypothesis. Did the Samsung representative provide more details about the factory OS bug?
    04-10-2016 09:46 AM
  24. Wildo6882's Avatar
    If the reps don't know about it, what did you tell them in Best Buy to get it taken care of?
    04-10-2016 09:59 AM
  25. Alpha Male PR's Avatar
    In the conversation between me and the Samsung representative we agreed that maybe that was the problem, so she proceeded to install a fresh copy of the operating system on my phone.
    04-10-2016 12:37 PM
  1. S7 Edge screen protector messes up after putting on case
    By pst23 in forum Samsung Galaxy S7 edge
    Last Post: 08-22-2016, 09:00 AM
  2. Hopefully you guys can help me out - WiFi issues
    By say anything in forum Samsung Galaxy S7 edge
    Last Post: 03-13-2016, 09:18 AM
  3. Replies: 0
    Last Post: 03-12-2016, 11:20 AM
  4. Replies: 0
    Last Post: 03-12-2016, 11:03 AM
  5. My Alcatel Pop C7 doesn't turn on
    Last Post: 03-12-2016, 09:59 AM
