08-09-2017 01:22 AM
694 ... 1920212223 ...
tools
  1. Str0ntium's Avatar
    The system update Tmobile rolled out yesterday has completely fixed the problem. It doesn't even pop up when I turn the phone on anymore. It's gone completely! Wahoo! It's been almost 24 hours. I'm a heavy user and I was getting the notification about 10 times per day and every time on startup. Now nothing. Hope other carriers fix it soon as well. Phone is fantastic and my only complaint has been addressed. Although I do wish the home screen had continuous panning. Oh well.
    Gone on bootup? Could be they just disabled the notification altogether. How about when you unmount and mount the card manually? If it doesn't notify in that scenario then it does not sound like a fix for the underlying issue, to me.
    Replacement handset resolved my issue.
    05-05-2016 02:11 PM
  2. ogio's Avatar
    This is what I'm thinking. Sounds like the notification was just disabled.
    05-05-2016 06:36 PM
  3. ogio's Avatar
    I was getting this notification on my replacement phone also. I just got another replacement phone today. However this phone is an older build date and has some faint scratches on the screen. I think i might just send it back and deal with my phone.......
    05-05-2016 06:38 PM
  4. Anatar's Avatar
    So here's something interesting; I haven't gotten one sd card notification popup since the ATT update back around april 20th, however in my Sd card notification app, it has many logs of sd card unmounted / bad removal / ejected. I popped the card out only one or twice, so that means the issue still exists, but I no longer get an sd card notification when it unmounted,which I'm okay with ,but it's not technically fixed. It's line putting a bandaid on a cut, it's still there, but you can't see it.
    05-05-2016 08:08 PM
  5. ogio's Avatar
    do you get a notification sometimes when you use the camera, about saving pics to card? or was that notice disabled too?
    05-05-2016 09:08 PM
  6. boulianc's Avatar
    I agree. The notification was just disabled. There is still a problem with the phone since it is still ejecting it randomly without "us knowing" anymore. Its more a way to hide the problem. I believe that this is because the hardware is faulty.
    05-06-2016 09:45 AM
  7. felloffthetruck's Avatar
    Installing the new Verizon update now. Hope it fixes this problem.
    05-06-2016 11:41 AM
  8. ogio's Avatar
    On the update page, if you click on link "learn more online" it states the update eliminates the sd popups.
    I'm going to do the update. And keep an eye with the SD card monitor to see if the card still unmounts.
    felloffthetruck likes this.
    05-06-2016 01:13 PM
  9. felloffthetruck's Avatar
    Just updated my phone and the SD notification was there after the phone rebooted. I'm just praying this update fixes the problem once and for all.
    05-06-2016 01:38 PM
  10. ogio's Avatar
    Install the SD card monitor app to really see if it works
    05-06-2016 02:39 PM
  11. ogio's Avatar
    ok, i installed the latest verizon update today, and one of the listed fixes is the sd card notification issue.
    well, all the update did was to remove the error message. my 'sd card monitor' app shows continued unmounting and remounting. nice job verizon!
    05-06-2016 06:33 PM
  12. Str0ntium's Avatar
    Thanks for the info. Hope I have the right packages disabled to avoid a forced update. Really retarded of them. My phone is working fine, don't need their lame attempt at hiding an issue (all of the carriers seem to be in on it, at this point).
    Not shocked that they, unlike TMO and ATT, did not enable the FM radio. Seriously considering going back to TMO.
    05-06-2016 07:23 PM
  13. pkaczor's Avatar
    Confirmed that SD Card Monitor is showing multiple ejections since taking the VZ update. Reinstalled Good Lock...
    05-06-2016 07:45 PM
  14. ogio's Avatar
    here is the list for the latest update
    http://www.verizonwireless.com/support/samsung-galaxy-s7-edge-update/
    i like the dual clock always on display.
    05-06-2016 08:18 PM
  15. physicsguy's Avatar
    Same. Two unmount/bad removal in the four hours since the update. First ones since April 29, so the update seemed to make it worse for me. But no notifications at least, right? ::eye roll:: Worst attempted cover-up of a known issue. ever.
    05-06-2016 09:01 PM
  16. htc4life77's Avatar
    I've been following this thread from the beginning. From what I have gathered...
    Samsung came out with a new phone and in less than 2 weeks started running a BOGO on the first batch of their newly manufactured phones...
    If its only an android 6 issue than why is it inconsistent for some people than everyone using the same type of micro sd. This makes it seem like the problem was there early on and they tried to unload a bad shipment on early adopters... My phone works with an older samsung micro sd card 64gb but not my new 128 gb sandisk. I've actually sent my sd card to sandisk for repair so I know the issue is not with the card. My friend who has the same phone running the same card (we bought the same one on black Friday) is not running into this issue that he knows of currently. I would suggest everyone install the sd card monitoring app because some may not notice it's happening if they are casual phone users. I recently sent my phone to Samsung for repair for the issue after testing functionality, doing a ntf 1st attempt lvm they found no issues but did replace my SIM card tray which they said was "cosmetic". I'm 20% hopeful that this has resolved the issue but it seems more likely cheap hardware causing compatibility issues with certain sd cards that's why some users have reported success using a smaller slower sd card as generally that is easier to be compatible with. All I know is the same cards on my htc m7/m8 had no such issues....at this point regretting my impulse buy for the Samsung BOGO deal...will update once I get my phone back. I plan on using a 200gb+ micro sd in the future so I would like this problem resolved...
    05-07-2016 01:33 AM
  17. Ramma09's Avatar
    This is an old problem. It's the SAME the Samsung Galaxy S3 had. I've ruined multiple sd cards from all brands that used to work fine with others devices for years.
    It's clearly a hardware problem that they couldn't fix.
    it has nothing to do with marshmallow or a bad card tray. If you don't take out the sd card it will eventually stop working; it won't be recognized by any device.
    You'll have to learn to live without expandable storage like I had to do.
    Wish you all best of lucks. The S7 is a great phone.
    05-07-2016 12:54 PM
  18. ShinyTop's Avatar
    I think it appropriate to remind everyone that many of us, I expect most, have not experienced this issue, not even once. That does not mean it is not hardware, it does mean it is not a hardware design issue.
    jlczl likes this.
    05-07-2016 03:30 PM
  19. ogio's Avatar
    wait, what?
    05-07-2016 03:34 PM
  20. jlczl's Avatar
    I agree. I read about this issue so I wanted to see what all the fuss about. There is 3 Galaxy s7 Edge phones in my family and each of them have memory cards. I have a 200gb SanDisk, one of the others has a 128gb Lexmark, and the other has a 64gb SanDisk. None of them have ever had this issue other than when they are restarted, which I believe is the way they're supposed to work.
    If it was a hardware design issue all of us would have it. It is likely a random hardware issue that only affects a relatively small batch of the total phones manufactured.
    05-07-2016 04:24 PM
  21. Ramma09's Avatar
    The thing is, this "small batch" of samsung phones was never acknowledge by samsung and even if they replace your unit you are not guaranteed to have the problem solved. I think that it's not acceptable with an expensive premium phone.
    05-07-2016 08:11 PM
  22. Str0ntium's Avatar
    We have this thing, in photography. There are tolerances for bodies, and for lenses. So, the lenses can be within say +/- 0.5% for what they say it's specs are. The body, also, has a tolerance of about the same for it's acceptability.
    If it so happens that the lens is - 0.5% within tolerance of the targeted spec and the body is + 0.5 % within tolerance of the targeted spec, guess what? You get issues.
    This is what happens when you have different components with different tolerances that eventually are paired to work together.
    There may be something like that, going on here too.
    05-07-2016 10:28 PM
  23. Str0ntium's Avatar
    Sorry, but phones have cost this much for many years now. I would hardly call it 'expensive' or 'premium'. It's a mass produced, disposable consumer electronic. It depreciates very quickly, as well. The next version will be available 12 months from the date of this one.
    05-07-2016 10:36 PM
  24. ogio's Avatar
    6 sd unmount errors logged today. but the update prevents the message from popping up.
    i do get a message though when i use the camera, and phone tells me an sd card is inserted and will store pics on it.
    this is no fix at all. all they did was remove the damn error message.
    05-07-2016 11:46 PM
  25. Sammuel1973's Avatar
    Since the last TMOBILE update, I no longer see the sd card notification.
    05-09-2016 05:55 AM
  1. S7 Edge screen protector messes up after putting on case
    By pst23 in forum Samsung Galaxy S7 edge
    Last Post: 08-22-2016, 09:00 AM
  2. Hopefully you guys can help me out - WiFi issues
    By say anything in forum Samsung Galaxy S7 edge
    Last Post: 03-13-2016, 09:18 AM
  3. Replies: 0
    Last Post: 03-12-2016, 11:20 AM
  4. Replies: 0
    Last Post: 03-12-2016, 11:03 AM
  5. My Alcatel Pop C7 doesn't turn on
    Last Post: 03-12-2016, 09:59 AM
