hillybillycrash
Active member
Because you should be able to increase the memory without buying a new phone.
This notification keeps popping up a couple times a day. I've formatted, mounted, unmounted the card and it's still haunting me.
Is there any way to stop this?
So, someone tell me again why the S6 and iPhones suck for not having an SD Card slot?
When I unmounted my card manually through the settings, it re mounts itself later and the notifications start againWell I unmounted and uninstalled the sd card 18 hrs ago. (No more sd card notifications obviously) I haven't had any random reboots either. I have been averaging 6-12 per day using various apps, surfing the web, and even during phone calls. Issues all started 6 days ago right after Sprint pushed Marshmallow on my Note 4. If any more reboots occur I will do a factory reset and hopefully get a cleaner 6.0.1 install. Im thinking corruption somewhere.
It does not bother me it only shows up when I reboot the phone a simple swipe and it's gone.
That means your phone is functioning properly and you are not experiencing the notification issue that people are having in this thread. That's a nice thing, enjoy your phone.
To the others in the thread, I was lucky and swapped mine out for one without this issue, but I continue to follow this thread as how Samsung addresses this issue will impact how I feel about them as a company (this is my first Samsung Android phone). I will be crossing fingers for a positive resolution/solution soon!
Did they ask you to send the defective one back?Just talked to the best Cell company in the world (AKA T-mobile) and they're sending us new phones on Monday. Will keep y'all posted On another note, the fact that Samsung is STILL not owning this has earned them a complaint with the BBB. Folks, we have a government to which we pay A LOT of taxes so it would work for us: use it.
On a funny note: The Tmobile technician to whom I spoke had just bought an S7. So, when I was done telling him that this is a wide-spread issue and he got to read this thread, he responded: "REALLY? That's not good. I should get an SD card for mine soon then to see if it's defective."
Hopefully, this nightmare ends on Monday; fingers crossed.
S.
