1. PJRed2008's Avatar
    Still messing with the Edge capabilities and have not been able to get the scrolling feed to work. I installed a CNN edge scrolling widget, which is activated and set with notifications on, but the motion the manual shows to activate edge scrolling just gives me a small display at the end of the edge screen that shows a small checkmark and the city and state I live in. Got to be missing something but unable to find a setting or something else not set.
    03-12-2016 01:43 PM
  2. bsteppuhn's Avatar
    You have to swipe your finger up and down the side when the Phone is locked and the always on display is on
    03-12-2016 05:21 PM
  3. bsteppuhn's Avatar
    I just figured this one out today!
    john290 likes this.
    03-12-2016 05:21 PM
  4. PJRed2008's Avatar
    That's what I explained I was doing in my OP. All I get when that is done is the checkmark and my city/state. Even though I have an edge feed app installed, I get nothing other than the small notice I described.
    03-12-2016 05:54 PM
  5. Lobwedgephil's Avatar
    Do you have edge feed set to on as well as the edge panel?
    03-12-2016 06:25 PM
  6. PJRed2008's Avatar
    Yes, as best I can tell anyway. The feed itself has notifications turned on but I can't see any way to deal with the feed itself. It's listed in Applications as a downloaded app but that is the only place I can find it.
    03-12-2016 06:37 PM
  7. Lobwedgephil's Avatar
    In setting, click on edge screen, make sure edge feeds is on, and click on edge feeds to select what feeds to show.
    PJRed2008 likes this.
    03-12-2016 06:42 PM
  8. PJRed2008's Avatar
    Yep, missed that one. Enabled the CNN feed, will see how that goes but I think you fixed it! Many thanks
    03-12-2016 09:47 PM
  1. Samsung S7 Edge... Typing issues
    By chappy5150 in forum Samsung Galaxy S7 edge
    Last Post: 10-12-2017, 04:54 PM
  2. No scrolling text messages in notification bar
    By nickjeep99 in forum Samsung Galaxy S7 edge
    Last Post: 08-04-2016, 08:18 PM
  3. Can I use a normal charger with s7 edge?
    By Andyvalver in forum Samsung Galaxy S7 edge
    Last Post: 04-20-2016, 04:46 AM
  4. Received my ATT S7 Edge with battery dead out of the box
    By rong21 in forum Samsung Galaxy S7 edge
    Last Post: 03-14-2016, 05:41 PM
  5. Why won't the s7 edge download any apps?
    Last Post: 03-13-2016, 09:25 AM
