1. Steven Friedmann's Avatar
    The fingerprint sensor is fast and very sensitive. It works great, until the device is restarted. Then, instead of being able to unlock with a fingerprint, it says "Swipe screen to unlock". After swiping, this pops up: "Enter password instead of using fingerprint recognition after restarting device to protect fingerprints".
    WTF?!?!
    I looked for settings to change this, but either I'm blind, or there are none. Any help would be appreciated! Or if it can't be changed, I would hope for an explanation from either Samsung or Google.
    theeddie99 likes this.
    03-12-2016 04:09 PM
  2. KimJongOMG's Avatar
    WTF?!?!
    Encryption. The phone can't get to the fingerprint scans until you unlock the encrypted device. Same way on the iPhones.
    03-12-2016 04:16 PM
  3. Steven Friedmann's Avatar
    Thanks! That seems reasonable, but I find it odd that they can figure out a way to access the encrypted password to unlock the device, but not the encrypted fingerprint. I think someone who develops these items should be able to come up with a creative solution for the 6.0.2 update!
    03-12-2016 04:23 PM
  4. KimJongOMG's Avatar
    It's because fingerprints are a biometric ID whereas a standard password is not. I wouldn't want hackers with my fingerprints doing God knows what should they somehow get them in their grubby little hands.
    I'm sure there's a more technical explanation but I'm not smart enough to get into that .
    Leslie Hatcher likes this.
    03-12-2016 04:25 PM
  5. scorpiodsu's Avatar
    Iphone does the same thing. I believe the explanation above applies there as well.
    03-12-2016 07:06 PM
  6. jsjxyz's Avatar
    Yes in iPhone it requires,
    but samsung has failed deductive logic:
    it required PW to open after startup, BUT you still can use the finger swype to change PW.
    Why don't it just required Finger swype directly if it can allow the access to change PW.
    06-14-2016 11:50 PM
  7. Ry's Avatar
    Are there any phones that will let you unlock from boot with a fingerprint?
    My Honor 5X behaves the same way as Apple and Samsung.
    Posted via the Android Central App on the Moto X Pure Edition
    06-15-2016 12:03 AM
  8. jsjxyz's Avatar
    iphone can't use fingerprint at all after restart.
    06-15-2016 12:18 AM
  9. Almeuit's Avatar
    Hm??
    06-15-2016 12:26 AM
  10. Alanhd's Avatar
    I read that the police can make you unlock a phone with your fingerprint but they cannot make you enter a password. This might have an indirect bearing on it.
    06-15-2016 01:43 AM
  11. chanchan05's Avatar
    Yeah, they can putty your fingerprints and it would work on the scanner.
    cooldudetouch likes this.
    06-15-2016 09:18 AM
  12. oks10's Avatar
    So, today we learned that if you ever get pulled over, immediately restart your phone! lol
    06-15-2016 09:24 AM
  13. Almeuit's Avatar
    Jerry wrote about that here -- Your privacy, your fingerprints and the fifth amendment | Android Central .
    06-15-2016 09:54 AM
  14. chanchan05's Avatar
    Oh before I forget, for those unconcerned the setting for this feature is under Lockscreen and Security > Secure Startup
    06-15-2016 10:33 AM
  15. Almeuit's Avatar
    This is for the actual boot of Android (as in asking for PIN like Jerry said before the system actually boots) but if you have FP setup it still asks for PIN before it will allow FP access (like iPhones) on the lock screen.
    06-15-2016 11:25 AM
  16. hammerjackjones's Avatar
    Two steps verification so the wife can't get you while you sleeping
    06-15-2016 05:14 PM
  17. Bogy's Avatar
    Interesting thread. My daughter and and I both have recently gotten S7s. Monday as I brought her to the airport we were comparing our impressions of the phone and I mentioned that one of the things I really liked and had been looking forward to in moving from an S4 was the ability to use my fingerprint to unlock the phone. She said her husband wouldn't let her use the fingerprint option because it was a security risk, hackers had broken into phones and obtained the fingerprints. It's not going to stop me from using my fingerprint, but I was wondering if anyone else had heard of this. I haven't had a chance to do any checking on it since Monday, and this thread reminded me. My son in law works for a major tech company, and is normally a very reliable source.
    06-15-2016 06:30 PM
  18. chanchan05's Avatar
    A putty on your finger to copy the print and it can work on the phone. As for hackers, they need access to your phone first. AFAIK Google doesn't back up finger print data. It stays on the device. So any hacker needs to find way in first.
    06-15-2016 08:00 PM
  19. reddbrad's Avatar
    I hate this. I just want to know how to put it back the way it was.
    WTF?!?!
    06-21-2016 02:08 AM
  20. Almeuit's Avatar
    If I recall correctly this is how it has always been since fingerprint readers have been around. If you don't want a FP simply don't setup a lock screen and you can swipe to unlock .
    06-21-2016 03:00 AM
  21. cooldudetouch's Avatar
    I don't know if anyone has actually realized, but this is a security feature designed to prevent someone who finds your phone (like if you've lost it) from unlocking it. When fingerprint scanners came out there was a huge controversy that anyone could use tape and putty, etc. and lift your fingerprint off the screen, make it into a mould and use it to unlock your phone. This sounds complicated but it was actually a simple process. That is why Samsung decided to prevent fingerprint unlocking upon a restart or not using your device for 24 hours.
    11-23-2016 06:15 PM
  1. Is the S7 edge screen easily scratched?
    By eak1570 in forum Samsung Galaxy S7 edge
    Last Post: 12-29-2016, 04:09 PM
  2. S7 edge sends text after reboot?
    Last Post: 04-01-2016, 05:58 PM
  3. My glaxliy s3 is purple green white black and won't turn on
    By MaKenzie Aldridge in forum Ask a Question
    Last Post: 03-12-2016, 05:12 PM
  4. What is com.samsung.android.visualeffects
    Last Post: 03-12-2016, 05:11 PM
  5. Replies: 0
    Last Post: 03-12-2016, 03:38 PM
