1. scotchipman's Avatar
    Where are the widgets located on the S7/S7 edge? I'm looking for a calendar widget that comes with the factory installed calendar.
    03-12-2016 04:27 PM
  2. wxman2003's Avatar
    Press on hold down any blamk part of the screen. You will see a list on bottom for Wallpapers, widget, etc. Tap the widgets and there will be many different ones to choose from.
    scotchipman likes this.
    03-12-2016 04:31 PM
  3. scotchipman's Avatar
    Thanks, love this forum!
    03-12-2016 07:16 PM
  1. Location Sharing not updating
    By StanTheGreenGuyFan in forum Samsung Galaxy S7
    Last Post: 03-16-2016, 03:00 PM
  2. locate a serial #
    By shellig604 in forum Ask a Question
    Last Post: 03-12-2016, 04:09 PM
  3. Replies: 0
    Last Post: 03-12-2016, 12:01 PM
  4. where is the antenna located on LG G3 ?
    Last Post: 03-12-2016, 08:34 AM
  5. Replies: 1
    Last Post: 03-11-2016, 11:03 PM
