1. sjfwhite's Avatar
    Hi folks - coming from a 6 month affair with an LG G4 that I am "gifting" to my daughter. One thing I liked about that device was the ability to tap the screen to turn it on. Is this available on the S7 Edge? I have hunted through the settings but can't find anything. Thanks!
    03-12-2016 09:28 PM
  2. jpdaballa's Avatar
    From my knowledge there is no setting for this option but there are a lot of apps in the play store that should be able to replicate double tapping to turn on the screen. I don't use this feature so I'm not sure which app works the best but you can search the play store for "tap tap app screen on off" and a bunch of different will pop up. Let me know if this helps
    sjfwhite likes this.
    03-13-2016 07:27 AM
  3. erasat's Avatar
    If you go to Settings-Accessibility- Dexterity and interaction, you'll find an option to firm your screen on even without touching, it's very convenient but by its nature it takes some toll on the battery.
    Try it and see how it works for you.
    03-13-2016 09:14 AM
  1. Google apps won't connect on home wifi on new S7 Edge
    By Drdwyer18 in forum General Help and How To
    Last Post: 03-18-2016, 12:53 AM
  2. Screen won't light up
    Last Post: 03-12-2016, 09:18 PM
  3. Replies: 0
    Last Post: 03-12-2016, 08:24 PM
  4. why does my Samsung note 3 beep when I 'm on a call?
    Last Post: 03-12-2016, 07:28 PM
