1. Josh1377's Avatar
    I have noticed the always on display will fade, basically grow darker occasionally. Then it'll get brighter for awhile and fade a little. Is this normal? After every five minutes does it fade a little and brighten with the time change?
    03-12-2016 08:38 PM
  2. B. Diddy's Avatar
    Moved to the S7 edge forum.
    03-13-2016 05:29 PM
  3. bsteppuhn's Avatar
    I've noticed this also
    03-13-2016 05:52 PM
  4. Josh1377's Avatar
    I wasn't sure if it had anything to do with the brightness in the room or battery usage. I assume or hope this is committed, but I didn't know if anyone else knows of this. Thanks
    03-13-2016 05:58 PM
  5. Techno-guy's Avatar
    Seems to me like it's a room brightness thing but it is definitely not consistent.
    03-13-2016 06:01 PM
  6. t11rmh's Avatar
    It is a brightness thing.
    Posted via the Android Central App via a kicking Gold Galaxy S7 Edge.
    03-13-2016 06:05 PM
  7. felloffthetruck's Avatar
    Ours do this also.
    03-13-2016 06:46 PM
  8. jaltman's Avatar
    Its an ambient light thing. Cover up the ambient light sensor and several seconds later it will dim.
    rdrive41071 likes this.
    03-13-2016 07:36 PM
  1. Message preview on lock screen?
    By ShaneN. in forum Samsung Galaxy S7
    Last Post: 03-26-2016, 05:27 PM
  2. Google apps won't connect on home wifi on new S7 Edge
    By Drdwyer18 in forum General Help and How To
    Last Post: 03-17-2016, 11:53 PM
  3. Tap Screen to Turn On
    By sjfwhite in forum Samsung Galaxy S7 edge
    Last Post: 03-13-2016, 08:14 AM
  4. why does my Samsung note 3 beep when I 'm on a call?
    Last Post: 03-12-2016, 06:28 PM
