1. SamsungGalaxyFan73's Avatar
    Hello!
    I spent few hours last night on this issue. Everytime I transfer my contacts from either iPhone, LG G4 or Google contacts to Samsung S7 Edge. I get duplicates contacts. I can't seem to figure out way?
    Anyone else have this issue too? How do I fix it?
    Thank you,
    Jamie
    03-13-2016 10:07 AM
  2. bsteppuhn's Avatar
    I just linked the contacts together
    03-13-2016 10:10 AM
  3. Gator352's Avatar
    Hello!
    Thank you,
    Jamie
    Go into your contacts app. Top right and select more. Select settings. Select contacts to display. Pick the one that suits you.
    03-13-2016 11:35 AM
  4. ZMc1834's Avatar
    I only have this issue while inside the Verizon Message+ app. It shows my contact's number 4 times. When I look inside the actual contacts app, I only see one.
    03-13-2016 11:38 AM
  5. PJRed2008's Avatar
    On mine, the first "set" on contacts were not contacts but just placeholders showing "new" contacts. Listed after them were the actual contacts. Touching the first set makes them go away because they are no longer "new". Haven't found a way to clear them all at once so I'm just ignoring them for now. This is using Google contacts and my Gmail account. YMMV for other accounts.
    SamsungGalaxyFan73 likes this.
    03-13-2016 11:59 AM
  6. Alanhd's Avatar
    Before I switched from my S5 I had the problem of multiple duplicate contacts , what I did was move all the contacts to my google account, then when I signed into my google mail via a web browser and selected contacts, it has a setting to merge all duplicates. I was amazed how many different sources I had linked together over the years.
    03-13-2016 11:59 AM
  7. SamsungGalaxyFan73's Avatar
    Thank You!!!!
    03-13-2016 12:24 PM
  8. SamsungGalaxyFan73's Avatar
    Thank you!!!
    PJRed2008 likes this.
    03-13-2016 12:28 PM
  9. pcfiremedic's Avatar
    There is also the option in your online google contacts account to delete any multiples of the same contact instead of merging them. If you merge contacts that all have the same contact number, it will show all of those numbers repetitively in the contact.
    03-13-2016 05:23 PM
  10. BreniOK's Avatar
    Galaxy S7 go to Settings -> Applications -> Contacts -> Merge duplicate contacts
    08-11-2016 09:01 AM
  11. JaneWMoreno's Avatar
    Never heard that Galaxy can do this.
    02-15-2017 12:30 AM
  1. HELP! My phone can't move apps to SD card
    By Rayhan Nugraha in forum ASUS ZenFone
    Last Post: 03-16-2016, 05:31 PM
  2. Replies: 1
    Last Post: 03-13-2016, 04:02 PM
  3. Changing from 16gb to 64gb, help still needed
    By joekido in forum Samsung Galaxy S5
    Last Post: 03-12-2016, 11:36 PM
  4. Can't Hookup Corporate Email HELP!
    By droidfamily in forum Samsung Galaxy S7 edge
    Last Post: 03-12-2016, 08:47 PM
  5. duplicate contacts with Message +
    By ictmitch in forum Samsung Galaxy S7
    Last Post: 03-12-2016, 08:39 PM
