1. pinkvikchick's Avatar
    Love this dang phone. Love the SD, had it all set up and was about to go for a run when I accidently tapped eject on my sd card when I just wanted to see the storage. I waited for it to finish "ejecting" and turned the phone off, pulled sd card slide out, put back in and says sd card is corrupt. Take out again, checked on laptop, everything is there and pretty. Put back in phone. I don't get a corrupt message, and I'm happy for a second. But, through "files" I can see everything on my card, but can't see any off the apps or music in the music app or photos through the photo app. Settings/storage shows minimul storage. They're there, the phone SEES it, it just ain't using it. So I research and google and decide to try to do a hard reset before formatting and starting from freaking scratch. That's the first thing I need help on, why the hell is it doing this! Eject shouldn't have screwed things up.
    NOW I've held the power and down volume simultaneously for almost 2 minutes and nothing happens...google app comes up and my volume goes down but WTF am I doing wrong? I've pressed at the same time, I pressed one a little faster than the other...time for a mimosa.
    PS I'm an *****! I was pressing the home key and the down volume, not the power LOL...waiting to see if anything changes.
    03-13-2016 10:45 AM
  2. Zendroid1's Avatar
    Are you holding down the home button and volume down instead of the Power button and volume down? I'm basing this on you saying Google app comes up.
    03-13-2016 10:49 AM
  3. pinkvikchick's Avatar
    Well, did the hard restart, only lost two widgets, which I can deal with (weird though, I wonder if that has anything to do with having these apps on my SD card?) And had to replace some apps on my panel (that were also on the sd card) so I'm happy. If the admin wants to remove it I'm aright with that. Or leave it so if someone else is doing same dumb thing...
    03-13-2016 11:01 AM
  4. pinkvikchick's Avatar
    I WAS!!!
    03-13-2016 11:01 AM
  5. KimJongOMG's Avatar
    Oooooo ouch! That seriously sucks! Did you format the card after putting it in the phone when it was new? I just ejected my SD card and can confirm it didn't populate apps on SD card until I did restarted the phone. Afterward, the apps came back but it took about 5 minutes to index all the pictures and music on the phone and show again.
    03-13-2016 11:05 AM
  6. pinkvikchick's Avatar
    Yes! I just had to wait a few minutes, everything came back. I was just being so impatient. AND I just learned that I do NOT get widgets when I move apps to the sd card. Moving apps to the SD card is new to me, I'll move the ones back to device that I need, but how awesome is this!!!
    03-13-2016 11:09 AM
  7. KimJongOMG's Avatar
    Double post
    03-13-2016 11:09 AM
  8. KimJongOMG's Avatar
    Haha glad you waited instead of jumping head first into a factory reset!
    pinkvikchick likes this.
    03-13-2016 11:10 AM
  1. constant pop-up...factory reset didn't fix it [Samsung Galaxy S5]
    By AC Question in forum Samsung Galaxy S5
    Last Post: 08-28-2016, 10:14 AM
  2. SD picture order messed up
    By lammy8 in forum Samsung Galaxy S7 edge
    Last Post: 07-29-2016, 03:41 AM
  3. Setting up a Theme
    By PatrickBaterman in forum Samsung Galaxy S6
    Last Post: 03-15-2016, 07:39 AM
  4. htc verizon m8 hanged up
    By AC Question in forum HTC One M8 Rooting, ROMs, & Hacks
    Last Post: 03-13-2016, 05:25 PM
