1. dodgeboy's Avatar
    I've had my phone for almost 2 weeks now (T-Mobile), and I'm not getting near the battery life that most people on here are seeing. As a result, I want to do a factory reset and restore my apps selectively. In the past, I've always used Titanium Backup for this purpose, and it can restore all of the settings/data for each app. But it requires root, which I obviously don't have. I backed up my phone with the Samsung Backup and Restore feature (in the settings menu). It was disturbingly quick, so I can only assume it's not backing up the data for my apps. Has anyone used this, and can you report on whether it saved the actual app data (where you're at in a game, login information, etc.)?
    I used Helium to get most of my apps/data on the phone (transferred from my LG V10). I'd like to avoid doing that again, if possible, just in case it has something to do with my phone's inability to idle.
    03-13-2016 10:57 AM
  2. KimJongOMG's Avatar
    Believe it just backs up your phone settings, Samsung apps, and apps you downloaded from the Galaxy app store.
    Could be totally wrong though.
    03-13-2016 11:16 AM
  3. dodgeboy's Avatar
    That would make sense, based on how quickly it completed... Thanks.
    03-13-2016 11:19 AM
  1. Samsung s7 stopped working. Can't see screen can't do anything
    By AC Question in forum Samsung Galaxy S7
    Last Post: 02-28-2018, 09:58 AM
  2. [Resolved] 6.0.1 how to change what holding Home button does
    By Himeko7 in forum Samsung Galaxy S6
    Last Post: 03-13-2016, 02:42 PM
  3. Replies: 2
    Last Post: 03-13-2016, 01:41 PM
  4. Should I Install Doze Or Does The S7 Software Already Handle That?
    By PsychDoc in forum Samsung Galaxy S7 edge
    Last Post: 03-13-2016, 12:11 PM
  5. Replies: 1
    Last Post: 03-13-2016, 11:48 AM
