1. Melinda Paiva's Avatar
    How do i stop Galaxy S7 Edge from automatically saving pictures from SMS to the gallery?
    03-13-2016 12:31 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Is it saving the full-sized picture, or just the thumbnail? In the Gallery app, select the photo and tap the Information button--how big is the file, or what resolution does it say it is?
    03-13-2016 12:49 PM
  3. lterry913's Avatar
    Are you using the built in messaging app or one from the market? I use chomp sms and I can toggle that off in chomp settings.
    03-13-2016 03:07 PM
  4. Melinda Paiva's Avatar
    Thanks. I downloaded the chomp app and removed the others. Problem solved.
    03-14-2016 10:36 PM
  5. rkkeller's Avatar
    What app were you using to begin with as the stock messaging app that came on the phone does not automatically save pictures to the gallery. I don't even see an option that would make it do that.
    03-15-2016 07:49 AM
  6. lterry913's Avatar
    When I was originally setting up the phone I thought I saw that option somewhere myself. I can not remember where. Maybe it's in an apps setting that has cloud storage. Ugh, wish I could recall where I saw it.
    03-15-2016 04:29 PM
  7. Melinda Paiva's Avatar
    I was using Message+
    03-16-2016 12:38 AM
  1. I like to buy unlocked galaxy 4or5with no contract
    Last Post: 03-13-2016, 01:02 PM
  2. Replies: 1
    Last Post: 03-13-2016, 01:01 PM
  3. Restoring messages from backup issue
    Last Post: 03-13-2016, 12:57 PM
  4. Do i have to UN encrypt my phone and card prior to root?
    By Mercedesdude1963 in forum Software Development and Hacking
    Last Post: 03-13-2016, 12:30 PM
  5. Replies: 1
    Last Post: 03-13-2016, 12:02 PM
