Google now launcher on edge
bhatech
Trusted Member
Nov 21, 2012
7,850
488
83
I use Nova launcher on my S7 edge, was playing with N on 6p and thought should get back to Google now launcher on my S7 as well. When I switched boy it looked ugly with that big icons, 4 column grid.. I mean wtf Google? Can't you figure out what device it runs and provide a larger grid? Nexus 6p has 5 column. I know we can root and change this but my rooting days have long gone. Hope Google provides an option in settings where we can change grid size. Back to Nova on s7 edge.
Is anyone using the Google now launcher and liking it on the edge even though it looks cartoonish with that big icons?
torbach1
1,008
I had the same experience, although I noticed it already on my N6p because I'm so used to the custom, smaller icon size I've been using with Nova. I love Google Now, and Is love to have it as one of my home pages, but Nova is just so much better.
What I did do, especially because holding down the home button now takes you to now on tap before you have to select the "G" to force it to Google Now, is that I added a swipe up gesture to my browser icon and gave it the action of opening Google Now.
franklinexpress
You can have the grid size like on nexus 6p, just use the hidde. Condensed scaling feature on the s7 and you'll have 5 column grid in the google launcher. I used this app to show the hidden menu https://forums.androidcentral.com/e...ls?id=com.evozi.displayscaling&token=Ioh90bdq
srikat
Active member
Aug 13, 2011
29
It is also possible to swipe the left edge of your phone (to the right) from anywhere and have Google Now appear when using the default launcher, using apps.
