1. rong21's Avatar
    I used it for the first time today. Was successful.
    Question, if the machine has a chip reader will Pay still work?
    03-13-2016 01:34 PM
  2. KimJongOMG's Avatar
    Yes. I think there might be information embedded into the magnetic strip of cards that have a chip in it that tells the machine the card has a chip. Since Samsung Pay doesn't, it shouldn't trip that. I've never had issues using Samsung Pay on card machines with active chip readers.
    03-13-2016 01:37 PM
  3. anon(238680)'s Avatar
    My understanding from the Samsung site is yes, but I can't verify that.
    If I may partially hijack your thread , I'm wondering if Pay will automatically turn on NFC on the cell. I keep NFC off and have not had a chance to try Pay at a vendor yet.
    03-13-2016 01:39 PM
  4. SamsungGalaxyFan73's Avatar
    Yes. Chip reader has nothing to do with Samsung Pay. :-)
    03-13-2016 01:40 PM
  5. rong21's Avatar
    thanks guys. As for NFC I keep it off as well. I turned it on before use manually so not sure
    03-13-2016 01:42 PM
  6. Rashawn29's Avatar
    It automatically turns nfc on.
    anon(238680) likes this.
    03-13-2016 02:23 PM
  7. anon(238680)'s Avatar
    Outstanding! Thank you.
    03-13-2016 02:30 PM
  8. limitbreak09's Avatar
    I tried it once and nfc automatically turned on
    03-13-2016 02:43 PM
  9. Polen's Avatar
    You do not have to have NFC turned on. When you activate Samsung Pay with PIN or finger print, NFC turns on and then off when transmission stops. You can also verify this with your screen unlocked, open Samsung Pay by app icon, select credit card, activate with PIN or finger print, while it is pulsing swipe down from top to expose top of screen, you should see the NFC icon.
    Another cool thing is Samsung Pay uses a different credit card number every time you activate it. At work we have USB card scanners and we opened up Notepad on the PC and held the phone over it and it popup the credit card info on the screen and every time we did it the number was different. Cool stuff.
    Also, my card has a chip and Samsung Pay works just fine. Both NFC and MST.
    04-14-2016 08:58 PM
  10. oks10's Avatar
    I've only had a failure happen once so far, at Whataburger of all places... Not sure why it didn't work. Meanwhile it work at CVS (pharmacy store) that the cashier said wouldn't work with Android or Apple pay.
    04-14-2016 09:36 PM
  11. Hapa_Dude's Avatar
    It didn't work for me once on a Clover terminal. Maybe I was holding it in the wrong spot or maybe because the guiderail where you slide the card was metal not plastic like all others. I'll try it again though next time I go to that restaurant for lunch.
    Otherwise, the Samsung Pay is fast and convenient. Definitely a cool feature to have!
    And yes, it works on Chip terminals.
    04-14-2016 11:05 PM
  12. Polen's Avatar
    I have had a couple of failures. The credit card machine said Bad Card at HEB, Lowes and Sam's Club. Cool thing happened tonight at Jason's Deli. They don't have customer facing CC machines, but I said to the girl, "Can I pay with my phone?" and she said, "Do you have one of those COOL phones?" I said, "Yes!" She said, "Yes." So I reached over the counter to the card swipe on her cash register and it BEEPED and she handed me my receipt. Cashier are all asking, "What kind of phone do you have?"
    04-21-2016 08:29 PM
  13. llckll's Avatar
    Used it successfully everywhere except for Lowe's.
    04-22-2016 12:17 PM
  14. RockyMin's Avatar
    I still can't get it to work when I have to enter my PIN. I spoke with my bank and they said everything is authorized properly and everything. But whenever I have to enter a PIN I get invalid transaction.
    04-22-2016 12:41 PM
  15. meyerweb#CB's Avatar
    To the OP, the answer is probably yes.
    If the card reader accepts both chipped and magnetic stripe cards, then it should work. When you try to swipe a chipped card, the card itself tells the read that it has a chip, and the reader will prompt you to insert the card instead of swiping it. When you use the same card through S.P., your phone doesn't tell the reader about the chip, so it processes it as a normal swipe transaction.
    I was at one retailer recently, however, whose readers will no longer accept a magnetic swipe card at all. The slot where you would normally swipe was simply not there. I didn't try to use my phone, but I'm willing to bet it wouldn't have worked.
    Unless, that is, the reader is also equipped for NFC. Samsung Pay will use the NFC it it's available, and the mag reader if there is no NFC. I didn't notice whether these "slotless" readers had the NFC logo or not.
    04-22-2016 03:47 PM
  16. jexx's Avatar
    RockyMin-
    Did you sign your card in the app? This has caused problems for many users.
    Also, in case you were not aware? This link to the SP Forum is very informative and helpful: Samsung Pay - Android Forums at AndroidCentral.com
    04-22-2016 06:57 PM
  17. anon(1733)'s Avatar
    My card had a chip in it and I use Samsung pay all the time no issues.
    04-22-2016 10:22 PM
  18. rong21's Avatar
    I use Samsung pay more than my card
    04-23-2016 03:25 PM
  19. qz0xr3's Avatar
    Works great for me too. It's nice not having to pull credit or debit cards out of my wallet.
    My only "issue" is that the transactions aren't being recorded in Samsung Pay. So, I'm not getting credit for the transactions and thus eligible for the promotions Samsung is offering. I'm a BBVA Compass customer and this is a known issue that BBVA is working through. Other cards (like my AmEx card) is working just fine. But again, that's a bank issue ,not a Samsung issue.
    06-07-2016 11:49 AM
  20. Almeuit's Avatar
    Are you backing out of the payment right when it is done? You have to let it sit up and it will hit. I have noticed it not logging if I back out since it may take a few entries on the CC machine (like credit .. amount correct yes.. etc. etc.) but if I just leave it and continue on that it will pop up on Samsung Pay.
    06-07-2016 11:55 AM
  21. qz0xr3's Avatar
    I'm not sure. I have no problems with other cards, just BBVA's. I don't think I'm doing anything differently from what card to the other. When I called BBVA, they said that their tech department is aware of the issue and is working on resolution.
    Almeuit likes this.
    06-07-2016 12:43 PM
  22. Almeuit's Avatar
    Ah okay .
    06-07-2016 12:45 PM
  1. My s4 samsung mini was dead but now have this on screen
    Last Post: 03-13-2016, 03:17 PM
  2. samsung mega gt-i9152 camera flash flashing phone wont start
    By IAF in forum Samsung Galaxy Mega 5.8
    Last Post: 03-13-2016, 01:54 PM
  3. Replies: 0
    Last Post: 03-13-2016, 01:23 PM
  4. Replies: 1
    Last Post: 03-13-2016, 01:16 PM
  5. samsung mega gt-i9152 camera flash flashing phone wont start
    By IAF in forum General Help and How To
    Last Post: 03-13-2016, 12:52 PM
