Dan TheMan86
Wait, how does this work on old credit card machines? Won't it only work on machines that have the little wifi looking logo?
It is safer than using the actual credit card. Anyone could steal your card and use it with no verification. At least the phone requires a pin or thumbprint to use. Also it doesn't transmit your registered card number, it uses a temporary one use number for each transaction.https://youtu.be/aT5jPJ1IWu0
OMG...it generates magnetic fields to trick old machines! Now I get it. Wow, couldn't this be hacked and used by criminals somehow?
Try downloading from Google play again. It may work. It didn't come pre installed on verizon.I can't get Samsun Pay to even open. S7E on ATT. When I click the app it tells me it needs to install. I click install and it won't ever go past the install screen. And, since it's bloatware, I can't uninstall it to re-install it. I can't even deactivate it. All I can do is force stop it and then open it again only to have it stick at the install screen.
Try to clear the cache and data then install it again.
Oh wow, what about going through a drive through or a place where the card machine can only be accessed by the cashier? So awkward to hand them your phone. And don't you have to have your fingerprint on there for it to work? How could a cashier take it and use it?
Damn US is so backwards.. In Canada they pass us the interact machine even in drive throughs
my amex blue card has the chip, works fine........
If they require chip to pay, then it won't work. However most of those machines will have NFC enabled.Question is what happens when many terminals go from swiping your card to dipping it in the slot with the chip?
