1. grumpton's Avatar
    So, I have the stock clock widget on my home screen, but I'm used to it being interactive. By this, I mean that I should be able to tap the time and have it open the clock app which includes the alarm settings. I can't figure out how to do this and am assuming that the widget is not interactive.
    Anyone know if I'm wrong and how to do this? Otherwise, what clock widgets do you guys use that are interactive? Also, it would be nice if it showed the time of the next alarm if it's set up. I don't need to have the clock app on my home screen just for that, but.....
    03-13-2016 03:36 PM
  2. Brian Street's Avatar
    Doesn't appear to be interactive. I downloaded the Google clock. It's widget is interactive and shows the next alarm.
    03-13-2016 04:59 PM
  1. Change clock on lock screen (XWidget)
    By klinger1 in forum Samsung Galaxy S7
    Last Post: 03-15-2016, 10:52 AM
  2. Replies: 10
    Last Post: 03-14-2016, 11:24 AM
  3. Stock Weather Widget
    By Bryant Laney in forum Samsung Galaxy S7 edge
    Last Post: 03-13-2016, 07:28 PM
  4. Weather and clock widget on Galaxy s6 will not update to DST
    Last Post: 03-13-2016, 03:24 PM
