02-27-2017 10:13 PM
101 ... 2345
tools
  1. danaman's Avatar
    It may be a faulty SIM card.
    Troubleshooting I followed as I was finding that my S7 either turned off for no reason/ or froze at the clock screen many times a day forcing me to start it again with the power & volume down buttons: -
    1) Nothing resolved it by restoring or one by one deleting installed apps or a factory reset
    2) I had to leave the phone on Airplane mode & then it didn't crash so narrowed down that it was only when using 3G/ 4G that the problem occurred
    3) Samsung support advised me to check by switching a new SIM if the SIM was the issue
    4) I swapped the SIM to another S7 & still had the same problem in the replacement phone
    5) My wife put in her SIM into the suspected faulty phone & never had any crashes...so it wasn't the phone
    6) Got a new SIM & it's all good no crashes at all
    This is the 1st that I had heard that the SIM could be the cause & couldn't find it in other blogs.
    Not sure if problem would only arise for an S7 with a faulty SIM card.
    Good luck!
    08-14-2016 09:35 PM
  2. TheZuneLune's Avatar
    I am having the reboot issue, as well, and have been intermittently having an issue where I lose cellular service and get an error saying there is no SIM card. Thanks to this thread, I will go to Verizon and see if a new SIM fixes the problem.
    08-16-2016 12:17 PM
  3. mlblack16's Avatar
    Mine rebooted constantly. It wasn't the SIM. Verizon arranged for me to get a replacement S7 edge and I put my previously used SIM and microSD in the replacement phone. This one so far has been great.
    08-17-2016 06:01 PM
  4. danielbelfiore84's Avatar
    I have a s7 . Not edge but it's doing the same thing. Restarts about 2 times a day. I called att and they said to bring it in to either fix or replace but I really don't wanna start over with a new phone.
    10-02-2016 01:38 PM
  5. JOC2016's Avatar
    About 2 weeks ago I put mine through a factory reset to fix a calendar storage issue - since that point it ran wonderfully and I was ecstatic to finally have it functioning. Then last Thursday I went on a long car journey and bluetoothed it to the car for the first time - since that moment in time it has crashed several times an hour whether blue toothed or not. I took it into a Samsung store, but as I suspected they would not entertain it as it was a Chinese import to the UK through a website (totally genuine, with no invalidation on the software in theory, but not within UK warranty). They did put it on their computer and said there were many software glitches and suggested a factory reset. The problem is that I am almost certain I'd lose the handset in the system if I sent it back under warranty - I waited about 6 weeks for delivery in the first place. So I'm looking at a another factory reset. Several questions please to help this time:
    1. From turning it back on after resetting, can anyone point me in the direction of what order the Android set-up screens occur - you know those ones you get when you first turn on a new out of the box phone. I muddled through last time but was guessing as they all come up in Chinese and it is a while before you can get to settings to change it to English. There is plenty on the web about doing the factory reset - I can get to that point as its all in English, but once done all the welcome screens are in Chinese and it would be helpful to know what order to enter the data in. Things like logon details etc. or even which side the 'skip' buttons are so that I can quickly find settings and get back English. Or what are the quickest set of options before I can access languages. I can do other settings later. I can't remember the screen order when I first unboxed it when it had actually been sent to me in English
    2. Could the Bluetooth have crashed it - several others on this thread have mentioned Bluetooth. If so why and what it is the best thing to do to stop it please? Before I did the factory reset for the first time (to fix the calendar storage) the phone was often bluetoothed to the car without problems.
    3. A long shot - is there any way of getting it to factory reset to English rather than the default Chinese? I can still get to the software as I can soft reset it and get it to function most times for a little while.
    10-03-2016 02:42 AM
  6. Neocorteqz's Avatar
    I had no reboot issues until tmobile did the last update on the on the edge 7.
    I've noticed bluetooth is usually on connected or not. I do have a theme installed as well, so maybe I will kill the theme first, see if that helps. If not I will turn bluetooth off and see what happens.
    Will post results later.
    10-24-2016 11:57 AM
  7. amyf27's Avatar
    On my phone at least, Google play services isn't causing problems.
    Maybe Google play services needs updated. How long ago did you get the phone? Sometimes the carriers can troubleshoot over the phone, or Samsung may help as well, if you're able to get hold of them
    10-24-2016 12:05 PM
  8. yanger's Avatar
    I'm in the same boat as you...I didn't have any issues until the Tmobile update a couple days ago.
    I even did a factory reset and it is still having problems.
    10-24-2016 02:19 PM
  9. yanger's Avatar
    My response earlier should have quoted your post.
    Having random restarts since the last Tmobile update.
    10-24-2016 02:20 PM
  10. rnhunsaker's Avatar
    Likewise. My S7 Edge was a stabile as a granite mountain until the recent T-Mobile update. Does anyone know how to roll it back?
    My phone was a running little warm when the reboots were happening this evening. I disabled Bluetooth. The phone is now cool. But, this is a very short test interval. It will be interesting to see what happens over the next few days. It will also be interesting to hear what others experience.
    10-24-2016 07:55 PM
  11. yanger's Avatar
    Just wondering, do you use a smart watch? That's the main reason my Bluetooth is always on for me.
    I'm starting to think it is bluetooth related. I'm either on my car bluetooth or I get a notification on my watch before it restarts but that may just be coincidence since my phone is always connected to something.
    I'll shut down Bluetooth and see what happens.
    10-25-2016 08:48 AM
  12. yanger's Avatar
    Just as a follow up to this...I have not had bluetooth running for over 24 hours and it's been rock solid so. No unusual battery drains, no restarts....
    Which sucks if that is the issue - miss my watch.
    10-26-2016 01:12 PM
  13. mlblack16's Avatar
    From my experience with this issue, if a factory reset doesn't solve the problem, the next step is to visit Samsung Experience store inside Best Buy to have them reflash the phone. If that doesn't fix it, then it's a bad motherboard. I think there were batches with this issue and my first S7E was one of them.
    10-26-2016 05:24 PM
  14. David towle's Avatar
    First, I'd like to say I absolutely love my Samsung Galaxy S7 Edge and what it can do, when it's not restarting itself. This problem has only begun a few days ago but it's getting more and more frequent. I've deleted the apps that I installed that I thought my be causing the glitch. I've done a factory reset and it worked for a little while.
    Is anyone else having this issue?
    Mine freezes and restarts, only when using amazon video. Happens every time I'm using it. Usually about 30 minutes into a video.
    10-31-2016 05:54 AM
  15. rnhunsaker's Avatar
    I think I solved my problem. After the last T-Mobile update, my wife's S7E and my S7E each picked up the spontanious reboot problem. Turning off Bluetooth eliminates the symptom but is an unacceptable "fix". I also tried cleaning Bluetooth Share Cache and firmware cache without success.
    My "fix" is disabling "Samsung Gear". Once done, neither of our phones reboot automatically. Yay!
    10-31-2016 06:00 PM
  16. yanger's Avatar
    I've found the same thing...however, that's not really an acceptable fix...may have to try the reflash next.
    11-01-2016 11:15 AM
  17. rnhunsaker's Avatar
    It is not just an unacceptable fix, it really isn't a fix at all. It forces a lack of functionality on the customer. A factory reset is "easy and convenient" for T-Mobile and Samsung but it is an unacceptable burdon to the customer.
    After further testing, disabling Samsung Gear appears to reduce the number of spontaneous reboots. Unfortunately, the reboots still occur. The reboots seem to be more frequent when the S7E phones are close to another bluetooth device (headset, speaker, computer, tablet, vehicle, etc.). Again, disabling bluetooth stops the reboots but at the cost of a major function of the Android phone. Shame on Samsung. Shame on T-Mobile.
    We called T-Mobile support and they disavowed the problem but we hope that the next T-Mobile update will correct the problem without requiring a factory default reset.
    One of our phones is inoperative on the 700mhz band. A reconditioned phone is not available. Someday in December of January, (due to the S7E being out of stock) I will apply all of the firmware updates, do the factory reset and then reinstall all of my apps.
    11-03-2016 09:52 AM
  18. rnhunsaker's Avatar
    I'm at the end of my story. I backed-up my data, did a factory restore, restored my data. My problem is solved. HOWEVER: I'm seven hours into restoring all of my settings. This would have never happened if T-Mobile had tested before pushing the update.
    ABOSWORTH007 likes this.
    11-04-2016 05:10 PM
  19. Ahmad Iftikhar's Avatar
    Yeah im also having this same issue..whats the solution?
    11-05-2016 06:22 PM
  20. rnhunsaker's Avatar
    I was sooo happy to say that my problems were solved by doing a factory reset of my S7E. Nope. After a few days, my S7E went back to it's evil ways of random reboots.
    I just read on another forum that the November T-Mobile update solved the problem. I guess that might make sense because the October T-Mobile updated caused the problem. I'm downloading the November T-Mobile update now. Crossing my fingers.
    amyf27 likes this.
    11-10-2016 06:12 AM
  21. Chitharanjan K's Avatar
    I too had the same problem. I did factory reset many times and also wiped cache. No improvement. It always gets crashed whenever I install Google play services. So I disabled all the Google apps and my phone was working normal. No restart at all. Then I installed and updated Google play services... it again started restarting. So according to me the culprit is GOOGLE PLAY SERVICES
    12-21-2016 01:40 PM
  22. playaglitter's Avatar
    My S7 started the restarts randomly after my phone had completely died a few weeks ago. I went to a T-Mobile store and they assured me not to do a factory reset but that I would get a refurbished phone. In the meantime I did wipe the cache, which worked for awhile yet it soon went back to random restarts. I picked up the refurbished phone and we did the Samsung Smart Switch to transfer contacts, pictures and videos and as I was driving out the refurbished phone restarted as well. I went back to the T-Mobile store and told them what happened and they ordered another refurbished phone for me, telling me I should also do a factory reset to the refurbished one I had as I might of transferred a virus over, I went home and did a factory reset yet once again the restarts continued to happen, not to mention that this refurbished phone also wouldn't let me download apps and no one could hear me on phone calls. I picked up the second refurbished phone and that one within an hour or so also did the restarts. I went back to the T-Mobile store and they wanted me to get another refurbished phone or call Samsung. I got a loaner phone for them in the meantime as I was going to send my phone to Samsung, however I went to Verizon who is about to let me trade in this faulty S7 for a new iPhone7. I returned my loaner phone to T-Mobile to get my Galaxy S7 starting again before I would go over to Verizon, T-Mobile put a new SIM(?) card into the Galaxy and it actually was fine for a day. I had one restart the day after, and the day after that only two. Today I've had two restarts as well. I've wondered if it has anything to do with Google Maps? I'm still annoyed but not nearly as annoyed as I was and I'm continuing to debate if I should just jump on the iPhone bandwagon and be done with all this craziness of the Galaxy S7....
    12-24-2016 04:02 PM
  23. Tsepz_GP's Avatar
    Those of you having reboot problems, are you using Package Disabler and/or Greenify?
    In my 1st week with my S7 Edge I tried using Package Disabler, and Disabled a whole lot of things, what that lead to was a lot of instability and one day I woke to a phone that didn't want to wake up out of Standby, I knew it was up as it was flashing the Notification LED yellow, the colour I set for WhatsApp Group Chats.
    After rebooting the phone I immediately Re-Enabled all that stuff in Package Disabler and Uninstalled it, never had an issue again, in fact I find my S7 Edge to be the most stable smartphone I have ever had, it never misses a beat, no matter the abuse
    12-25-2016 06:31 PM
  24. Paul36pvu's Avatar
    Hello Everybody,
    I have been having a lot of this problem in the last month. I have tried all troubleshootings on the Internet and I have discovered the following:
    - Problems have started with the last updates of Android 6.0.1, especially after Google introduced the system with giving permissions manually to apps on what to access.
    - I reinstalled the software with Smart Switch 5 times now and still have this issue once every couple of days
    - I have uninstalled all updates of Google Play and Google Play services, and they are automatically updating by themselves
    - I have uninstalled all apps and kept just what I really needed and the ones from big developers
    - I removed the SD Card
    Still once every couple of days it restarts, but in the beginning it was getting extremely hot and bootlooping.
    My guess is that the new permission system or one of the latest security updates is having a conflict once in a while with Google play services (which is used by some apps) and some apps. I am waiting for new updates for our Android system. Hopefully that will resolve it because it is a very annoying issue! I really like this phone, but this restarting problem is really irritating for any user, especially business users.
    If you guys have other opinions or suggestions, please share with us! I believe all of us want this problem to have a clear solution on the web!
    All the best to you guys!
    01-09-2017 05:16 AM
  25. Paul36pvu's Avatar
    New update! I took it to the Samsung Service Center and they told me they will change the mainboard and the battery....................
    01-10-2017 10:18 AM
101 ... 2345
  1. Rooting Galaxy S7
    By AC Question in forum Samsung Galaxy S7 Rooting, ROMs, & Hacks
    Last Post: 11-22-2016, 05:28 PM
  2. Create Folders on Galaxy S7 Home screen
    Last Post: 09-16-2016, 12:10 PM
  3. Galaxy S4 not connecting via phone bluetooth
    By AC Question in forum Samsung Galaxy S4
    Last Post: 03-19-2016, 07:45 PM
  4. App won't write to sd card
    By AC Question in forum Lenovo Android Tablet Discussion
    Last Post: 03-15-2016, 01:54 PM
  5. I can not send videos to google drive or otherphones
    Last Post: 03-13-2016, 09:53 PM
