1. bsteppuhn's Avatar
    The day I activated I had 4g. I've been in 1x pretty much since then. What gives? -98 dBm 1 Asu is my current status
    03-13-2016 08:44 PM
  2. sydneycooper1979's Avatar
    Have you tried turning on airplane mode and then turning it off? Do you have enhanced calling activated (Voice over LTE)?
    03-13-2016 08:48 PM
  3. bsteppuhn's Avatar
    I just switched out if the global network it helped some! I went to the lte/cdma
    03-13-2016 09:17 PM
  4. dpham00's Avatar
    Yeah lte /cdma is the correct setting
    03-14-2016 05:44 PM
  5. bsteppuhn's Avatar
    I was set for global
    03-14-2016 06:03 PM
  6. felloffthetruck's Avatar
    You have to enable "Advanced Calling" or you will be stuck with the 1x for every call.
    Beware that this will add the video camera icon to your dial pad. I don't like the video camera icon on my dial pad but it is what it is.
    I would also stick with the global setting.
    03-14-2016 06:08 PM
  7. bsteppuhn's Avatar
    I have the advance on but without the global on I've had no issues. 3-4 bars and 4g vs global 1x and 1 bar.
    03-15-2016 08:21 AM
  1. S7 edge Reception issue
    By limitbreak09 in forum Samsung Galaxy S7 edge
    Last Post: 11-06-2016, 01:10 AM
  2. Network reception
    By Scottpot in forum Samsung Galaxy S7 edge
    Last Post: 03-13-2016, 08:19 PM
  3. Video calling on vzw
    By reykjavik in forum Google Nexus 6
    Last Post: 03-10-2016, 10:25 AM
  4. Replies: 0
    Last Post: 03-10-2016, 12:36 AM
  5. VZW's UPGRADE promo expired 2/29 - a rant
    By tomatosouplabs in forum Samsung Galaxy S7
    Last Post: 03-02-2016, 01:23 PM
