06-07-2016 12:07 PM
52 123
tools
  1. jinzen's Avatar
    I got an S7 Edge to replace an S6 Edge Plus. So far, the only thing that's actually improved is the sizing (good hand feel and ergonomics) and battery life (by maybe 20%, especially in idling ability).
    Everything else though, Samsung still makes these defective displays left and right: S7 Edge seriously not impressive - defective display, overheats... better battery life is good...-20160313_193636.jpg
    Half left side red and half right side is blue. Very obvious when reading Kindle in the dark or any website really in a gray or dark screen.
    Device gets HOT when doing anything intensive, and slows down significantly when trying to multi-task.
    Disk performance is really lacking, it is not ANY faster than my S6 Edge plus on daily interface usage on 5.1.1 or a Note 5 on 6.0.1.
    Everything else just seems to be the same, the only saving grace is that battery life is noticeably better in the Edge.
    I will be most likely returning mine and not exchanging and playing the "non-defective samsung display" roulette (similar to the Apple display roulette but much more painful).
    03-14-2016 06:14 AM
  2. SR45's Avatar
    Sorry to hear this, but mine has no issues with the screen. Your the first post thus far I've read about this bad screen being made left and right from Samsung. Perhaps others will weigh in. Take it back, get another or go with another manufacture.
    03-14-2016 06:31 AM
  3. brava27's Avatar
    Return it and get another one
    angeljavy likes this.
    03-14-2016 06:36 AM
  4. t11rmh's Avatar
    With a screen like that you should definitely return it and get another one.
    Posted via the Android Central App via a kicking Gold Galaxy S7 Edge.
    streetkilln likes this.
    03-14-2016 11:22 AM
  5. Almeuit's Avatar
    As for your issue it sounds like you may have just got a lemon. My screen doesn't have that issue and if it did I would exchange.
    As for the heat thing -- Any device heats up when put in intense situations. Mine only got "hot" when I was loading all my apps over LTE. After that the phone only gets a little warm when doing more intense tasks on it.
    03-14-2016 11:55 AM
  6. xocomaox's Avatar
    That screen is definitely not good. A return is recommended.
    Since you are going to return the device, you should check GSAM to see what the temperatures are reaching during intense activity (there is a graph with that information) so you can compare it with the new phone. This will give you an idea of what to expect.
    Just to let you know, my phone does not go above 37ºC (98ºF) under any circumstances. This includes gaming and charging for extended periods of time. Please let us know what you find.
    03-14-2016 12:03 PM
  7. anon(5630457)'s Avatar
    I have the red and blue hues like you when looking at a white screen, but just along the edges. I thought that was normal...?
    03-14-2016 12:07 PM
  8. xocomaox's Avatar
    The edges will always display discoloration due to the angle. But it should not be half and half like the OP's picture.
    03-14-2016 12:13 PM
  9. mrmugman's Avatar
    Agreed, you must have received a lemon. Mine has been pretty flawless since I got it on 3/11. Return the one you have and get another one.
    Tatt2014 likes this.
    03-14-2016 12:23 PM
  10. dpham00's Avatar
    When you say overheat
    ... Are you getting the cooling down message?
    03-14-2016 05:39 PM
  11. TMavC5's Avatar
    Everything else though, Samsung still makes these defective displays left and right: Click image for larger version.
    Have mine since last week and i'm not experienced any of your issue. You should return it and get a replacement.
    03-14-2016 05:41 PM
  12. jinzen's Avatar
    Just returned and got a replacement. The display is better, on par with my S6 Edge Plus.
    Heat wise is the same as the other one. CPU-Z reports the battery temps reach 36.5C - 37C. Of course, the actual SoC Reaches 60-70C. This was just downloading stuff and installing apps and doing updates, gets very hot.
    One other thing I noticed is that Marshmallow has a slower interface speed than Lollipop! Ugh! It's the delay when tapping on an icon or hitting the back button, now is about the same speed as an iPhone 6S whereas my S6 Edge + responds to input much more immediately (despite having problems keeping apps in memory).
    03-14-2016 05:52 PM
  13. Dubss's Avatar
    Please remember the heat is being dispersed off the CPU that's causing the back of the phone to get warm. There is a copper pipe inside your phone google on it there's a tear down I wish I had to link show you. As far as the screen I have no issues like that on my screen as mentioned above take it back
    lammy8, Tatt2014 and angeljavy like this.
    03-14-2016 06:15 PM
  14. Dubss's Avatar
    Check this video out it may shed some light on the heat in the back of your phone
    03-14-2016 06:21 PM
  15. mrmugman's Avatar
    When I first got mine the buttons were slow to respond due to all the app downloading / updating going on. After a few hours the key response was back to normal. Everything is nice and snappy.
    03-14-2016 06:23 PM
  16. lammy8's Avatar
    Thought of turning off animations under the dev settings? Think you're nit picking personally, it's plenty fast and responsive IMO.
    The back will get hot due to heat dispersal along the radiator pipe as already stated. Does cool pretty quickly mind.
    03-14-2016 06:40 PM
  17. jinzen's Avatar
    It is noticeably slower than my S6 Edge Plus in normal phone navigation. It's probably a bit faster than an iPhone in interface nav but I can definitely notice the difference between Lollipop and Marshmallow. It's just more infuriating how Android always seems to take a step back somewhere in every new OS. I'd rather take the S7 Edge hardware with iOS at this point.
    03-14-2016 06:53 PM
  18. Adranalyne's Avatar
    I'd say this is faster than my Note 5. Not by a huge margin, but it's noticeable. I think the consensus here is that you got a lemon, but I'm guessing you're not of that mindset even though most personal accounts and pretty much every review states the opposite of what you're complaining about.
    03-14-2016 07:12 PM
  19. sfla99's Avatar
    In developer mode you change the speed of the animations so if that is your only gripe it's a simple tweak, you can even turn them off completely if you like
    03-14-2016 07:21 PM
  20. ThrottleJohnny's Avatar
    I noticed it's slower than the 6 edge plus also. It just takes some getting used to. Marshmallow is actually much smoother than lollipop.
    03-14-2016 07:25 PM
  21. jinzen's Avatar
    No, it's Marshmallow. I have 2 S7 Edges, one I returned and the new one I'm using now which is fine. Both are/were noticeably slower in navigation than Lollipop. Most people just won't notice it.
    03-14-2016 07:43 PM
  22. Malek J's Avatar
    Exynos or s820?. Cut mine is way faster than the s6 edge plus
    03-14-2016 09:37 PM
  23. streetkilln's Avatar
    I don't really see the display issue with urs. If your talking about one side is bluish greenish and other side is yellowish orangeish , that's nothing new. That's been an issue with phone since qhd came out.
    03-15-2016 03:29 AM
  24. streetkilln's Avatar
    Also if you want a fast device get a stock Android device or close to stock. Reason why phones like Samsung is slow and laggy is because of there ****ty overlay OS optimization with current aos.
    03-15-2016 03:31 AM
  25. jinzen's Avatar
    Exactly the problem here. Samsung counts on consumers like you to not tell the QC issues and be perfectly happy with 1/2 of a red screen.
    My new S7 Edge has an even screen, and my S6 Edge Plus has an even better one.
    03-15-2016 06:14 AM
52 123
  1. Is this malware? How do I get rid of it???
    By AlyssParadox in forum Ask a Question
    Last Post: 05-20-2016, 06:01 AM
  2. Phone is not responding to anything!!
    By AC Question in forum Sony Xperia Z
    Last Post: 03-22-2016, 06:07 PM
  3. How my game can get good downloads.
    By AC Question in forum Developers Lounge
    Last Post: 03-14-2016, 04:17 PM
  4. Change of battery stats in Marshmallow 6.0.1
    Last Post: 03-14-2016, 05:07 AM
