1. dgurvits's Avatar
    Is it just me or is the palm detect feature that the previous edges gone now?
    Seems like i keep hitting apps accidentally with my palm a lot
    Do you guys know if there is a "sensitivity" setting or something similar?
    03-14-2016 06:38 AM
  2. Carlo Villa's Avatar
    That's why I love Nova Prime it will prevent that , they have a setting for locking the desktop so you won't accidentally hit or move the apps around.....
    03-14-2016 06:51 AM
  3. dpham00's Avatar
    You can use a case. There is no official touch screen sensitivity reduction option but there are some touch screen sensitivity apps in the play store. I haven't used any of them though.
    03-14-2016 07:15 AM
  4. dgurvits's Avatar
    Yup i know that option in nova, have been enjoying the stock launcher and resisting turning on nova prime
    03-14-2016 07:31 AM
  5. rkkeller's Avatar
    You will get used to how to hold it and it will be a non issue in a day or so.
    I only had the palm touch problem the first couple hours I had mine, then I just adjusted how to hold it and its never happened again.
    03-14-2016 07:35 AM
  6. Carlo Villa's Avatar
    So you know the answer ? OK then pay for Nova Prime and be worry free
    03-14-2016 09:04 AM
  7. MasterRy88's Avatar
    It must be the way I hold it but when I type I almost always hit the num button when trying to press the t. This is on the google keyboard. Its been quite an issue for me since day 1
    03-14-2016 10:25 AM
  8. dgurvits's Avatar
    I have nova prime
    I prefer the stock launcher to nova
    I was asking if the stock launcher had this
    03-14-2016 10:27 AM
  1. Do you think it's my LCD needs to be replaced?
    Last Post: 03-16-2016, 06:53 PM
  2. Galaxy s5 taking too long to "restore" after a factory reset
    By AC Question in forum Samsung Galaxy S5
    Last Post: 03-15-2016, 11:04 AM
  3. i would like to buy the S7 Edge in Tokyo Japan
    By AC Question in forum Samsung Galaxy S7 edge
    Last Post: 03-14-2016, 05:31 PM
  4. My Galaxy S 3 stopped receiving text messages last night.
    By Original ICEMAN in forum Samsung Galaxy S3
    Last Post: 03-14-2016, 04:01 PM
  5. Replies: 0
    Last Post: 03-14-2016, 06:24 AM
