Is anybody using poweramp on the S7 edge? My volume is extremely low compared to play music....anyone else?
Tried it again... Volume at halfway, I can't hear nothing on poweramp.... I use any other music player with the volume the same, I hear it the way it supposed to be..... Between this and the Aux static issue in my car, looks like I'm taking this back and going G5... Most likely... This is ridiculous....
Do this go in to settings audio advanced tweeks uncheck direct volume control for both direct and bt this will increase your volume to where it should be took me a bit to figure out but it fixed my poweramp low volume issue
