1. Kasper610's Avatar
    Is anybody using poweramp on the S7 edge? My volume is extremely low compared to play music....anyone else?
    Leo1986 likes this.
    03-14-2016 09:39 AM
  2. SIOP's Avatar
    Check the preamp setting in the equalizer.
    03-14-2016 09:49 AM
  3. Carlo Villa's Avatar
    This setting will make you go deaf
    03-14-2016 10:02 AM
  4. Kasper610's Avatar
    I tried everything, I almost have to max the volume to hear music at half way. Then I switch to play music player at same volume level and it's extremely loud! I've been having a lot of audio problems with this phone since Friday when I got it.
    03-14-2016 10:07 AM
  5. Kasper610's Avatar
    That setting did nothing for me. Are you using it on the edge?
    03-14-2016 10:08 AM
  6. PJRed2008's Avatar
    I agree with @SIOP, had to change the same setting, but works fine now. And yes, I have the Edge.
    03-14-2016 10:30 AM
  7. Kasper610's Avatar
    When I leave the volume at a qtr of the way up, I play poweramp, barely hear anything, I then play the play app, and I hear it just fine.... WTF!
    03-14-2016 11:01 AM
  8. knowledge_6's Avatar
    yep same here... what's even more F'd up is that when i play music in another app and come back to poweramp its like listening through some filter paper and a lot of static....
    i was about to return my device haha
    03-14-2016 11:18 AM
  9. Kasper610's Avatar
    Tried it again... Volume at halfway, I can't hear nothing on poweramp.... I use any other music player with the volume the same, I hear it the way it supposed to be..... Between this and the Aux static issue in my car, looks like I'm taking this back and going G5... Most likely... This is ridiculous....
    03-14-2016 11:30 AM
  10. knowledge_6's Avatar
    if this only happens with Poweramp.. it's the devs for poweramp that need to address compatibility ... haven't read your aux issue... but from a poweramp perspective it's the App ... they need to ensure it works on all types of hardware..
    03-14-2016 11:43 AM
  11. Kasper610's Avatar
    So basically, poweramp does not work on my S7.... Low volume, and static.... I grabbed blackplayer and it works just fine.... Not as good as poweramp, but will do until they fix it....
    03-15-2016 07:20 AM
  12. minoch's Avatar
    This has been discussed on other forums (XDA) it seems to only happen on Snapdragon versions of the S7 Edge.
    You are not alone.
    03-15-2016 12:28 PM
  13. Kasper610's Avatar
    Hope the devs are looking into that....
    03-15-2016 12:51 PM
  14. Shinigami Mai's Avatar
    Do this go in to settings audio advanced tweeks uncheck direct volume control for both direct and bt this will increase your volume to where it should be took me a bit to figure out but it fixed my poweramp low volume issue
    wxman2003 and rexx1234567 like this.
    03-15-2016 09:30 PM
  15. CrickKoyl's Avatar
    Try this, when not playing music change this setting:
    Settings > Audio Engine > Advanced Tweaks > Direct Volume Control DESELECTED
    08-26-2016 08:31 PM
  16. CrickKoyl's Avatar
    Oh I didn't see this was already answered.
    08-26-2016 08:36 PM
  17. BlutoSlice's Avatar
    PowerAmp 3 Alpha 704 has really improved things on my S7 (non edge exinos), it now is back to S4 volume behavior, and the new UI is nice too.
    Edit: Direct Volume Control tweak helped a little , using the alpha is a must.
    09-14-2016 12:47 PM
  18. KyloRenYaFace's Avatar
    You are my hero
    rexx1234567 likes this.
    11-28-2016 12:20 AM
  19. rexx1234567's Avatar
    You are a genius. I have seen those two settings for direct volume control and Bluetooth direct volume control, but I have never realized that could be the fix for the low volume problem. I did exactly what you said and it fixed the problem immediately.
    I am using a "ZTE Grand X Max 2" telephone with OS version marshmallow 6.0.1 . My Poweramp version is 2.0.10-build-588-play with no plugins installed.
    Just so everyone knows, having these two options enabled can also cause the "Replay Gain" (RG) features not to work.
    Also, if you have these two features enabled you will notice that the bass level decreases as you turn the volume up and the sound will become distorted when you turn the volume up to maximum. So it is best just to disable these two features all together.
    Thanks again to the person that posted the answer which is shown above, you have solved multiple problems with this fix.
    On another note, there is a separate issue that I think people here should know about. Whether you have DVC enabled or not the following issue will occur in version 2.0.10 or later. When using The Equalizer in Poweramp, if you try to increase the level of bands 2K, 4K, 8K, or 16k it will cause the treble knob to stop working. It seems that this is some sort of a glitch. The current Poweramp version that is available as of this comment is version V3 build 703 Alpha. In this latest version the issue is still not fixed. A workaround is to turn the "tone" button off and strictly use the equalizer to change the bass and treble.
    02-16-2018 12:38 AM
  1. Replies: 3
    Last Post: 12-20-2016, 10:37 AM
  2. Does touchwiz still have the high volume warning?
    By bable in forum Samsung Galaxy S7 edge
    Last Post: 03-14-2016, 11:07 PM
  3. How to set different volumes for different alarms
    Last Post: 03-13-2016, 11:26 PM
  4. On screen volume control
    By jkmail in forum Samsung Galaxy Tab S 8.4
    Last Post: 03-12-2016, 02:38 AM
  5. Full volume is much lower after upgrade
    By THEPRFCT10 in forum Motorola Droid Turbo 2
    Last Post: 03-11-2016, 09:34 PM
