06-24-2017 08:06 PM
41 12
tools
  1. dmcsql's Avatar
    Device: Samsung Galaxy S7 Edge
    Problem: Enter PIN instead of using fingerprint recognition because of security policy
    Solution: Clear cache and/or data (I did both) from Fingerprint app.
    Method: Go to Settings» Applications» Application manager» MORE» Show system apps» Fingerprint» Storage» Clear cache and/or data» Reboot» reAdd fingerprint(s) if necessary (wasn't necessary for me)
    Comment: After searching for weeks for a solution, ran across this solution for the Galaxy S5, decided to give it a try and voila! I'm one happy camper!
    09-06-2016 04:10 PM
  2. dcatiller's Avatar
    Is anyone else experiencing their s7 edge randomly requiring you to input your secondary lock screen password instead of the designated finger print scanner I've set as my unlock method?
    It'll just happen randomly. And too frequently too.
    Anyone else experiencing this? Kind of frustrating because I only want to use finger print to unlock.
    Anyone know what's going on here? Thanks.
    I have this exact problem, and I think it's a bug. It's also unsafe because it happens a lot while I'm driving. I reach down to open the phone with my fingerprint (something I can do without looking at the phone, using only my finger), but the phone wants a pin. I also have this problem with SmartLock enabled. In fact, I enabled SmartLock with the headset I havr on all day, thinking this problem would go away, but it hasn't. I reboot my phone 2 or 3 times a week out of habit, and this problem can happen 3 to 4 times in a day. I hope this gets cleared up in an update soon. It's really the only annoyance I have with what is otherwise the best phone I've ever had.
    09-07-2016 01:55 AM
  3. dmcsql's Avatar
    Did you try my solution above?
    09-07-2016 11:52 AM
  4. vgergo's Avatar
    Do you by any chance use a screen-off method other than pressing the power button?
    If found if I used the Nova Launcher action "Screen lock", the next time I tried to unlock my device it would not let me use my fingerprint / iris. I found this workaround: install the app "Screen off via short timeout" from the Play Store (by Dyna logix). If I assign this to the Nova Launcher gesture, the screen turns off (takes a few seconds longer) but I can unlock normally.
    https://play.google.com/store/apps/d....quick.timeout
    09-10-2016 08:02 AM
  5. erich wisdom's Avatar
    I knew this b/c us Nexus users have been experiencing this since sept of last year when Marshmallow came out. 😝
    I had it on my Nexus 6P because of Mobile Iron. I uninstalled it and still had the problem. A reboot cleared what settings were left from the uninstall.
    09-13-2016 08:25 PM
  6. Nandeesh N's Avatar
    If you turn off the screen using a regular Screen Off app, you'll be prompted for the pin. It's an Android Marshmallow security thing.
    To have the convenience of using an app to turn off the screen & not get prompted for a pin, you have to use a screen off app like this one:
    https://play.google.com/store/apps/d....screenlockpro
    this solution is PERFECT!!
    Thanks optimummind..
    10-13-2016 02:44 AM
  7. Shenoda Nabil's Avatar
    Thx really for this post it helped me alot identifying the problem. But if I'll buy this app; I'll be able then to lock the screen without using the power button and without using the pattern when unlocking again?
    10-29-2016 11:09 AM
  8. Pedro Henrique Linhares's Avatar
    No. It keeps asking for password after locking the screen
    10-30-2016 03:37 PM
  9. mrgigabyte's Avatar
    i have Screen Lock Pro and it works perfect everytime you have to check mark the setting for saying lollipop and mashmellow work around then the only time i have to do password is when i start my cell for the first time because i turn off when sleeping at night otherwise fingerprint works every time
    10-31-2016 11:07 AM
  10. bigmo555's Avatar
    I've had this problem on my Note 7 and S7Edge, but it's only when I use an app to lock the screen.
    Basically, if you lock the screen with the power button or when the screen times out, no problem unlocking with the fingerprint. Otherwise, you'll have to enter your PIN or password.
    10-31-2016 11:57 AM
  11. kayncz's Avatar
    The solution which works for me is a simulation of power button. Try this [root required]: Automate for Android ⋅ Simulate Power Button
    11-11-2016 02:04 AM
  12. Zero2016's Avatar
    11-12-2016 09:43 AM
  13. Saeed Farzpour's Avatar
    this is the exact answer to this problem.if you using apps to turn off your creen the app like power app it makes finger print in second place for opening your device so for solving this problem you need to remove all apps like this and use the standard fingerprint option from device.
    thx
    02-14-2017 09:57 PM
  14. Ed Felty's Avatar
    Yes my new S7 Edge is doing that and it's really annoying. I've gone back and reset my security settings to make sure its fingerprint only, and it was okay for a few days, but then it went back to the pass code periodically. I haven't found a fix yet.
    03-16-2017 01:31 PM
  15. Ed Felty's Avatar
    Hello Saeed, Thanks for the information but I still have one question, if a different app locks the device (not a power or security app) then the previous app which locked it, will the device require the pin again? Ie it locks while using a word processor then you unlock your phone and use Excel and it locks while in Excel, will that require the pin instead of the fingerprint? Thanks again!
    03-16-2017 01:45 PM
  16. Joeprez76's Avatar
    I have found a solution to the problem. Setup a SmartWake application to get permission from the use of prints. Acdisplay work like a charm. The developer is also include that app problem and solved. Galaxy s6 edge+ Nougat
    06-24-2017 08:06 PM
41 12
  1. How to get media controls on lock screen?
    By oceanclub in forum Samsung Galaxy S7 edge
    Last Post: 02-21-2017, 06:11 PM
  2. Replies: 5
    Last Post: 03-17-2016, 12:20 AM
  3. My Employer tells me not to use Outlook Mobile?
    By rld082982 in forum General News & Discussion
    Last Post: 03-15-2016, 10:45 PM
  4. Migrating From Blackberry to S7: Contacts Issue
    By DJYoshi in forum Samsung Galaxy S7
    Last Post: 03-14-2016, 01:56 PM
  5. Clock jumps to different positions on lock screen
    By leipemohn in forum Samsung Galaxy S7
    Last Post: 03-14-2016, 11:47 AM
