1. skhalid93's Avatar
    Anyones battery drain really fast when always on mode is set? Have had my phone for almost a week now and as much as it says its a power saver, it takes my battery out fast. Got a half days worth of life while I had it on. Just turned it off last night and today at this moment my battery is at 85% when usually it would be around 50/60%.
    03-14-2016 04:07 PM
  2. 20degrees's Avatar
    Nope. S7 edge and the battery lasts longer than the G4.
    03-14-2016 04:23 PM
  3. skhalid93's Avatar
    I'm talking about "always on" mode being enabled and disabled, where the clock and date show when your phone is locked. Not the actual battery life of the phone itself.
    03-14-2016 04:25 PM
  4. 20degrees's Avatar
    I know what you're talking about. I have it turned on and with it turned on, my battery still lasts longer than my g4 did.
    And I don't really notice a big improvement with it turned off. So I leave it turned on.
    03-14-2016 04:28 PM
  5. skhalid93's Avatar
    I've switched from iOS so i don't have an android to compare it to, but I have no idea. My phone with always on enabled states a 9 hour estimate before it dies. I've had always on switched off since last night and its been 6 hours without a charger and my phone has just hit 9 estimated hours. I also use my phone like I have every other day aka constant gaming and social media, so like I said, I have no idea
    03-14-2016 04:36 PM
  6. dpham00's Avatar
    Drains a little faster but not bad. Overnight I see about 1% an hour idle drain with always on display.
    pinkvikchick likes this.
    03-14-2016 05:27 PM
  7. bsteppuhn's Avatar
    With always on I only lose 2% at night I've played hard on mine today and I pulled it off at 715 and I'm only at 60
    03-14-2016 06:05 PM
  8. crazed_z06's Avatar
    Mine is draining fast, but I tried turning off Always On and it didnt seem to help at all.
    03-14-2016 06:19 PM
  9. pinkvikchick's Avatar
    No! I charged up to 100% and left it OFF a charger all night. 8 hours later, it was at 95% when I woke up. Shoot, my Note 5 used to 10% and not use anything!!!
    03-14-2016 06:29 PM
  10. pinkvikchick's Avatar
    This! Exactly!
    03-14-2016 06:29 PM
  11. skhalid93's Avatar
    I don't know how you guys got that.. I did that the other night, phone charged to 100 before i fell asleep, unplugged and when I woke up phone was at 85..
    03-14-2016 07:05 PM
  12. skhalid93's Avatar
    If you guys somehow have some way of saving battery with AoM enabled, I'm open to hear them
    03-14-2016 07:05 PM
  13. bsteppuhn's Avatar
    Did you look into the battery optimization I realised two of mine were still not checked. Do you run package disabler pro?
    03-14-2016 08:50 PM
  14. bsteppuhn's Avatar
    In the morning I'll take a picture of my battery stats for you
    03-14-2016 08:52 PM
  15. skhalid93's Avatar
    I can't check 6 apps on the optimization page, and yes I use package disabler pro.
    03-15-2016 08:11 PM
  1. How do I turn on app overlay options?
    Last Post: 03-17-2016, 05:22 AM
  2. Why don't i have emojis on my Google keyboard
    Last Post: 03-14-2016, 04:50 PM
  3. Replies: 1
    Last Post: 03-14-2016, 03:39 PM
  4. How do you clear the call history on the gear s2?
    Last Post: 03-14-2016, 03:25 PM
  5. Facebook error on application
    Last Post: 03-14-2016, 03:19 PM
