07-08-2018 03:33 AM
35 12
tools
  1. jb_bryant's Avatar
    Try ChompSMS. Made by the same guys at Textra, but I prefer the looks of it and had more features.
    I tried it for a bit. Can't remember what I didn't like. I didn't know it was the same people. I'll check it out again
    05-23-2016 11:29 AM
  2. oneflatwhite's Avatar
    For me I use BlackBerry Messenger (BBM) as you can request HD picture which actually the full size picture itself. It can be turn on by default. The interface also nice and its quite secure as you have to know the PIN (ID) of your friends and get accepted before you could even send anything.
    05-25-2016 10:09 AM
  3. Kevin OQuinn's Avatar
    Hopefully Tapatalk doesn't compress this.
    It's a screenshot of a screenshot that I sent from my Nexus 6p on the N Beta from Google Messenger to my Galaxy S7e.
    Looks great to me. Nice and sharp. All text and icons are completely legible.
    05-25-2016 11:35 AM
  4. Kevin OQuinn's Avatar
    Now that I'm looking at it on a PC I can see that there is a little bit of compression, but nothing like what I saw posted earlier in this thread.
    It's possible that Google Messenger just behaves better on Nexus or that this is a Samsung issue with the way Touchwiz handles things. Hard to say, but we've now seen that Google Messenger behaves correctly on a Nexus device. That leads me to believe that it's a device issue and not the app since the app behaves as expected on "the reference device".
    I do wish that the Samsung sms/mms app was on the Play Store so that it could be used on the Nexus to do the same test.
    05-25-2016 11:39 AM
  5. popkurn611's Avatar
    Hi all,
    So I have been using Google messenger on my edge and sent an imagine to my wife who is on an iPhone and when I saw what was delivered it was terrible in terms of quality, as if it was compressed to 20% of its original quality.
    I switched to the default messenger that Samsung provides and while it's better it still seems off, any ideas? Maybe Textra?
    Thanks!
    I've noticed this too recently my husband and I both have s7's, we came from iPhones so we had iMessage. Lately the pictures he has been sending me looked slightly fuzzy. When I got home I grabbed his phone and looked at the original picture he took and it's clean clear and crisp. I never realized images were compressed this much on Android.
    Someone said if you send the photo via Google photos it doesn't compress. I am going to try that next since we both have all our photos backed up to google
    05-29-2016 09:11 AM
  6. jb_bryant's Avatar
    https://uploads.tapatalk-cdn.com/2016...8d43eaae49.jpg
    Hmm yeah mine looked way worse. It seems very inconsistent to me. Sometimes the quick tray was high quality than the full photo picker and sometimes vice versa. By the way I know this is a Samsung thread but I am on an HTC 10 actually. I just found this thread searching.
    06-03-2016 09:29 AM
  7. Stwutter's Avatar
    You guys who are talking about compression because it's MMS don't know what your talking about. The Google Messenger app compresses if you use the quick select drawer fort pictures. If you go into these actual picture drawer you'll see that pictures send in normal quality like most other messaging apps (like Textra).
    I found this post looking to see if anyone knew if there was a way to fix this in the filesystem.
    Fort pictures? Like pictures of small castles?
    jb_bryant likes this.
    06-03-2016 10:42 AM
  8. jb_bryant's Avatar
    HAHAHA. You know what I meant
    06-03-2016 10:47 AM
  9. jhimmel's Avatar
    That's what I was doing, but they changed it and now it doesn't send full picture any more.
    10-16-2017 08:04 PM
  10. Zonggggggg's Avatar
    Hi all,
    Thanks!
    Simply use Bluetooth sending method. If you're using a laptop, find Bluetooth icon on the taskbar (it's usually on the right side). Right click and click "Receive File" > Go to that picture on your phone and choose Share and choose Bluetooth method and send it to your laptop. You should get full-quality image there.
    07-08-2018 03:33 AM
35 12
  1. Help! Restore Nexus 6 to Marshmallow from Android N?
    By AC Question in forum Google Nexus 6
    Last Post: 03-19-2016, 05:52 PM
  2. "Unlock effect" no where to be found in settings?
    By AC Question in forum Samsung Galaxy S6
    Last Post: 03-15-2016, 12:00 AM
  3. Annoying clean out apps notifications
    By eyet in forum LG G3
    Last Post: 03-14-2016, 10:30 PM
  4. Replies: 0
    Last Post: 03-14-2016, 09:29 PM
