Catch the unveiling of the Huawei Mate40 series
  1. torbach1's Avatar
    After you run it, it caused your home button and app switching button to stop working and the only fix is a full reset. Uninstalled the app doesn't do anything.
    03-14-2016 11:36 PM
  2. SpookDroid's Avatar
    Ummm... which Car Mode app? I've tried Car Mode on mine and it seems just fine.
    03-15-2016 01:29 AM
  3. torbach1's Avatar
    The Samsung one from the Galaxy App Store. Another user on Reddit had the same issue. It's the one that enables MirrorLink.
    03-15-2016 06:16 AM
  4. Mike-Mike's Avatar
    i have the car mode app installed, I haven't actually used it in the car, but I did install it and adjust the apps that displayed.
    but I have not had any issue with the home button or anything else
    03-15-2016 07:23 AM
  5. torbach1's Avatar
    That's encouraging. Hopefully this is a limited issue to my phone and one or two others. For the record, it wasn't until I had finished configuring it, and connected it to my car and tried MirrorLink that the home and apps buttons stopped working.
    The place I found the solution was reddit, where someone else had the same issue https://www.reddit.com/r/samsung/com...your_s7_or_s7/
    03-15-2016 07:46 AM
  6. SpookDroid's Avatar
    Maybe it's something with MirrorLink which, to be honest, I haven't tried.
    03-15-2016 07:45 PM
  7. Mike-Mike's Avatar
    i still haven't used it. I tried playing with it last night, is there a way to change the apps it displays? like it shows Google Play Music which is great, but I wanted to add PocketCasts, but I can't see anyway to adjust it
    03-16-2016 08:04 AM
  8. torbach1's Avatar
    Yeah, I didn't really want to try MirrorLink, but the VW system first tries Android Auto and Car Play, and if those don't work, it tries MirrorLink. I set it to default to Android Auto, but it kept trying MirrorLink. The phone told me to download the Samsung Carmode app to work with MirrorLink, so I got curious :-). I downloaded it, and after I configured it and connected, that's when it not only didn't work (showed a blank screen with a few buttons on the bottom row that were unresponsive), and after disconnecting, my home button and apps button stopped working. So I uninstalled the app, to no avail, cleared cache to no avail, and then googled it, and found the Reddit article.
    Now I used Package Disabler Pro for Samsung to disable the Carmode Stub (which was in place before). Lately, I have not been having as many problems with Android Auto, but it's still pretty unpredictable. I'm at the dealer right now for the software update, so I'll update later today.
    03-16-2016 08:52 AM
  9. torbach1's Avatar
    Yes, within the list of supported music apps, when you select Music, you can scroll to pick which one you want, and it will remember that. There is a Podcast app that is supported, but it's not a free one. Music wise, I know Google Music, Spotify, Pandora, and Amazon are all supported.
    03-16-2016 08:54 AM
  10. torbach1's Avatar
    I haven't had a chance to test it yet, but the service bulletin for the new software version clearly shows issues with both the Bluetooth system rebooting, and Android auto:
    03-16-2016 11:11 AM
  11. torbach1's Avatar
    So far, so good. The key is that as soon as you connect the S7/Edge, you'll get prompted whether to Allow access to the car. That message disappears pretty quickly.
    You have to select Allow before it disappears. If you don't do that in time, disconnect and connect again.
    03-16-2016 01:13 PM
  12. Jelly Belly's Avatar
    I need my eyes testing.
    I read the title of the thread and thought Samsung had branched out a bit by developing commodes. I hadn't thought of installing one anyway as we have a flush lavatory here.
    Jerry Hildenbrand likes this.
    03-16-2016 03:24 PM
  13. torbach1's Avatar
    I think that is coming in the S8.
    03-16-2016 04:23 PM
  1. Why does Google Music not show the album art?
    By leevill0311 in forum General Help and How To
    Last Post: 03-15-2016, 04:45 PM
  2. Issue with screenshot not editing after taking screenshot
    By SlackerMcFly in forum Samsung Galaxy S5
    Last Post: 03-14-2016, 11:23 PM
  3. Replies: 0
    Last Post: 03-14-2016, 10:01 PM
