1. Nkky7's Avatar
    Samsung pro plus 64gb or the gb 64 Evo Plus?
    03-15-2016 12:31 AM
  2. jpdaballa's Avatar
    I chose the normal Samsung pro. Best bang for buck cost for performance. It outperforms the evo + for around the same price on Amazon
    03-15-2016 12:40 AM
  3. Nkky7's Avatar
    the pro + is 49.99 thinking on buying it.
    03-15-2016 12:44 AM
  4. jpdaballa's Avatar
    Wow it dropped in price, I'll return mine for that if it's a reputable seller. Can you post the link?
    03-15-2016 01:42 AM
  5. jpdaballa's Avatar
    it just dropped to $40 i purchased it and will be returning my samsung pro
    http://www.amazon.com/gp/product/B01...cUvbUpU5061326
    03-15-2016 02:10 AM
  6. wxman2003's Avatar
    I have the pro plus and do not have the annoying sd card messages that pop up randomly that others are experiencing using different cards. It works great.
    03-15-2016 02:27 AM
  7. Nkky7's Avatar
    The one I saw was from adorama.
    03-15-2016 02:57 AM
  8. zipro's Avatar
    I have the pro + and the performance is absolutely phenomenal on the S7 EDGE.
    03-15-2016 08:32 AM
  1. Replies: 8
    Last Post: 08-20-2016, 06:00 PM
  2. will Samsung ever make an e-ink phone?
    By NimNice in forum Samsung Galaxy S7
    Last Post: 04-20-2016, 10:00 AM
  3. Warning. Do not install Samsung Carmode!
    By torbach1 in forum Samsung Galaxy S7 edge
    Last Post: 03-16-2016, 04:23 PM
  4. Can I switch SIM between Nexus 6P and Samsung S7 edge?
    By sniperservice in forum Nexus 6P
    Last Post: 03-15-2016, 08:11 PM
  5. How to root Digiflip pro ET701 tablet??
    Last Post: 03-14-2016, 11:18 PM
