1. AC Question's Avatar
    I run POP 3 email on my laptop, which is set to clear the server when it downloads to the laptop. When on the move I close my outlook and use my S7 to get copies on my phone. It is also using pop3. it is set to NOT delete email from Server.
    The problem comes in that in my old S6 edge, the inbox on the S6 will clear automatically when i downloaded to my laptop as the server is now empty, and phone will sync and reflect the same. HOWEVER, on the S7 copies of the email remains on the phone, and I want my inbox cleared during synch, when Email has been retrieved on my laptop. i am one of the few users that doesn't want copies to remain on my phone.
    paulhafer and piannetta like this.
    03-15-2016 06:15 AM
  2. rkkeller's Avatar
    Only IMAP email works like that I think.
    03-15-2016 09:11 AM
  3. paulhafer's Avatar
    With all due respect, I don't believe that is correct. I have used my pop 3 mail account for many years with every galaxy s series phone stock email app, and it has always performed properly as described above, until the s7. It makes no sense to do otherwise. Now if with the S7 Samsung has for whatever reason limited this functionality to only imap accounts, then this should be made very clear, and it has not been.
    piannetta likes this.
    04-13-2016 01:20 PM
  4. paulhafer's Avatar
    AC have you discovered a resolution on this matter, or is it a bug to be resolved...surely it's not a new "feature" by design...thanks, Paul
    04-13-2016 02:00 PM
  5. piannetta's Avatar
    Glad it's not just me having this problem...
    04-13-2016 03:43 PM
  6. paulhafer's Avatar
    I can tell you that regretfully so far, Samsung technical support has been completely clueless on the issue
    04-13-2016 04:25 PM
  7. paulhafer's Avatar
    as a followup, I installed a different email app (K9) and discovered that it worked correctly, deleting the email from the app inbox after syncing with an empty pop3 mail server...so I would guess the issue is not with Android 6, but rather with the Samsung email app
    04-20-2016 08:41 AM
  8. jinzen's Avatar
    It's Samsung email app... no need to look further than software issues with Samsung.
    04-20-2016 09:49 AM
  1. Why can I not swipe to delete my emails after the Marshmallow update?
    By johnjosephnelson in forum Samsung Galaxy S6 edge
    Last Post: 01-09-2017, 11:21 PM
  2. Which is the Best Short Story Mobile App?
    By AC Question in forum Android Apps
    Last Post: 03-16-2016, 12:51 PM
  3. how do I solve mount/sd error on my phone?
    Last Post: 03-15-2016, 01:33 PM
  4. How will I renew my Whatsapp subscription?
    By AC Question in forum WhatsApp for Android
    Last Post: 03-15-2016, 12:19 PM
  5. How do I move chat history to my new phone?
    Last Post: 03-15-2016, 08:31 AM
