1. AC Question's Avatar
    I have the galaxy s7 edge. I want to use my old notification tones from my s5. I transferred my tones but unfortunately when I try to assign al message tones to my contacts like I had before the only options I get are the basic pre installed sounds given on the device. I want to bypass the devices features and use my own can this be done. Thanks in advance for any assistance
    03-15-2016 10:24 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Did you copy the old tones to the Notifications directory on the new phone? The directory should be /storage/sdcard0/Notifications, not the one in the /system directory (which you can't access on an unrooted phone anyway). Also, are you using any 3rd party file managers like ES File Explorer? If so, make sure it's not the default app that comes up when you want to choose tones.
    03-15-2016 11:58 AM
  1. Why won't my notifications show on my lock screen?
    By Michelleadjei in forum Honor 5X
    Last Post: 08-10-2018, 12:59 PM
  2. Replies: 1
    Last Post: 04-09-2016, 11:10 AM
  3. Disable notifications on certain time frames ??
    By Rosa-het-schaap in forum Samsung Gear S2
    Last Post: 03-15-2016, 02:03 AM
  4. Annoying clean out apps notifications
    By eyet in forum LG G3
    Last Post: 03-14-2016, 10:30 PM
  5. Why is there a shape of a triangle in the notification bar all?
    Last Post: 03-14-2016, 08:43 PM
