1. scotchipman's Avatar
    Is anyone else having trouble getting Facebook account to sync of their S7/S7 Edge? I went to settings, account, Facebook and clicked on "Sync with your device" and checked the box but it still says Sync is turned off. I un-installed then re-installed the Facebook app with no luck. Any other suggestions? Thanks
    03-15-2016 10:51 AM
  2. B. Diddy's Avatar
    Are you trying to sync contacts? Facebook took that function away some time last year: https://m.facebook.com/help/communit...28796497164750
    Try Sync.ME.
    scotchipman likes this.
    03-15-2016 11:46 AM
  3. scotchipman's Avatar
    Yes, trying to sync contacts mainly so I have the Facebook picture for my contacts. Thanks for the information, had no idea Facebook removed that function. Will Sync.ME be able to sync with Facebook?
    03-15-2016 02:46 PM
  4. B. Diddy's Avatar
    I've never tried it, but others have said that it works.
    03-16-2016 11:38 AM
  5. scotchipman's Avatar
    Sync.ME does the job, thanks!
    B. Diddy likes this.
    03-17-2016 07:52 PM
  1. Replies: 2
    Last Post: 03-16-2016, 11:48 PM
  2. Number sync question.
    By AC Question in forum Samsung Gear S2
    Last Post: 03-15-2016, 05:06 PM
  3. Problem Syncing Calendars
    By TJGEsq in forum Samsung Galaxy S7
    Last Post: 03-15-2016, 10:18 AM
  4. Replies: 0
    Last Post: 03-15-2016, 07:25 AM
  5. Replies: 1
    Last Post: 03-14-2016, 10:20 PM
