1. jredfearn390's Avatar
    I was wondering if there was anything you "Android Freaks" (myself included) Did to keep your phones running flawless?. I know that Android does a great job . Let me know
    03-15-2016 11:02 AM
  2. brava27's Avatar
    I takeout the trash
    03-15-2016 11:04 AM
  3. Lobwedgephil's Avatar
    Keep buying new phones before performance starts suffering.
    bhatech likes this.
    03-15-2016 11:14 AM
  4. Almeuit's Avatar
    I don't do much to be honest since the phone handles itself pretty well. I have always rebooted my phones once per weekend just to do it since it is usually pretty quick but that is about it.
    03-15-2016 11:18 AM
  5. milehigherik's Avatar
    Once a week? I restart mine daily. To each their own. If you're not noticing slow down then I get it. I just am in the habit of restarting every morning before I take it off the charger. It also seems to prompt me to update Google play apps. I thought it should notify me as they're ready, however it doesn't. Sometimes a restart will notify that you have 15 apps to update.
    03-15-2016 11:42 AM
  6. mysterygirl's Avatar
    Agree, all I do is restart periodically. I used to do this daily (each morning), but have found recently that once every week or so is fine. I'm not even sure it has a real impact, but it's something I started with my first Android phone and have always done.
    03-15-2016 11:37 PM
  7. Almeuit's Avatar
    My phone normally will update apps via wifi / charging when I get home. I don't even have to really reboot once a week I just do it out of habit and figure once a week doesn't hurt anything.
    03-15-2016 11:56 PM
  8. jimbo1mcm's Avatar
    I used Wondershare Mobile go on my Droid Turbo 2 and it seemed to optimize the ram pretty often. I have it on my S7 Edge but it doesn't kick in hardly at all. The ram management seems very good.
    03-16-2016 01:57 AM
  1. Unless you use wi-fi, you will no longer be able to use internet?
    Last Post: 08-06-2018, 03:13 PM
  2. Replies: 10
    Last Post: 03-12-2018, 03:36 PM
  3. Can you get a Music player widget on the lock screen S6?
    By AC Question in forum Samsung Galaxy S6
    Last Post: 03-15-2016, 04:21 PM
  4. Replies: 1
    Last Post: 03-15-2016, 12:11 PM
  5. Why do my apps keep disappearing from my home screen?
    By AC Question in forum Android Apps
    Last Post: 03-15-2016, 11:02 AM
