1. AC Question's Avatar
    I want to be able to turn my data on and off through the use of my quick setting on my s 7 edge just like i am able to do with the wifi
    03-15-2016 12:10 PM
  2. src1425's Avatar
    If you mean the quick settings accessed by pulling down the top of the screen, expand the quick settings list by pulling them all the way down to the bottom of the screen, then select Edit in the top right corner, and then drag and drop the different toggles around to your heart's content!
    03-15-2016 12:55 PM
  3. GR0D's Avatar
    Switch it to Airplane Mode ON. Voila!
    03-15-2016 01:13 PM
  4. dpham00's Avatar
    If it can't be added to the pull down then your carrier disabled it. Look in the faq sticky for options.
    03-15-2016 01:55 PM
  1. Replies: 2
    Last Post: 09-03-2018, 01:51 AM
  2. Would leaving the night clock on 24/7 cause it to burn in ?
    By billyjoebob007 in forum Samsung Galaxy S7 edge
    Last Post: 03-15-2016, 03:44 PM
  3. I can only hear the caller if I am on speaker, why?
    Last Post: 03-15-2016, 12:37 PM
  4. Replies: 1
  5. Pair gear S2 to a Nexus 5X
    By faith3935 in forum Samsung Gear S2
    Last Post: 03-15-2016, 11:37 AM
