1. toshbar's Avatar
    I feel like hiding this makes the UI look significantly cleaner. I'm using nova launcher, which allows the option to hide the notification bar(not the drop down menu, but the bar) in the home menu but I was wondering if there is a way to hide it throughout all apps as well? The only time I care to see it is in the lock screen.
    Thank you
    03-15-2016 03:08 PM
  2. dpham00's Avatar
    Afaik, there is no option for this
    03-15-2016 03:38 PM
  3. Javier P's Avatar
    A few apps include immersive mode in their settings (Pocket, Flipboard, etc). You could also try Power Toggles and create a widget to switch this feature on & off. It's not perfect but worth a try.
    https://forums.androidcentral.com/e?...token=eXiZOADH
    03-15-2016 03:55 PM
  1. Troubles with the fingerprint scan?
    By phantomlink in forum Samsung Galaxy S7
    Last Post: 03-15-2016, 03:24 PM
  2. Replies: 1
    Last Post: 03-15-2016, 03:17 PM
  3. Replies: 0
    Last Post: 03-15-2016, 03:08 PM
  4. Lock screen "Personal message" deleted. Can I restore it somehow?
    By MichaelX99 in forum Samsung Galaxy S4 Rooting, ROMs & Hacks
    Last Post: 03-15-2016, 02:49 PM
  5. No text messaging previes in notification bar? (not pop up)
    By AC Question in forum Samsung Galaxy S5
    Last Post: 03-15-2016, 02:48 PM
