05-13-2018 06:52 AM
52 123
tools
  1. mavrrick's Avatar
    Did you ever change the channel you regular network runs on. That could explain why the second SSID would work better.
    03-16-2016 09:10 AM
  2. rkkeller's Avatar
    I am on ATT and get the same speed results with everything.
    03-16-2016 09:12 AM
  3. Awesome Moustache's Avatar
    Switched every channel on the router and still get the same results
    03-16-2016 10:56 AM
  4. mavrrick's Avatar
    What mode is the network running in. ie mixed, n only
    What security setting are you using. WPA2 hopefully.
    How long have you had the router.
    03-16-2016 12:19 PM
  5. pounder001's Avatar
    My local internet plan is up to 100 down and 10 up
    Both my AT&T S6 edge and new S7 edge are consistently getting the same 90 to 100mbps down and 15mbps up off of my 5ghz wireless router (DLink AC3200 Wi-Fi Router)
    03-16-2016 01:18 PM
  6. mpgrahn's Avatar
    I'm away from home right now and will test when I get back.
    03-16-2016 01:57 PM
  7. Awesome Moustache's Avatar
    Router is a Linksys WRT1200AC
    Network mode is mixed
    WPA2 Personal
    About 6-7 months
    As it turns out, that's the problem. Just for the hell of it, I set security to None, and now I get full speed. Set security to WPA2/WPA Mixed Personal, and it gets full speed. WPA2 Personal is the only setting that throttles the connection. May or may not be a Linksys thing...
    03-16-2016 02:09 PM
  8. mavrrick's Avatar
    That is actually a bit opposite of what I expected. WPA2 should be the standard for use with N and AC networks. Have you tried restarting your router.
    03-16-2016 05:41 PM
  9. Jerry Hildenbrand's Avatar
    It's likely the encryption type being used.
    Try switching to TKIP in your router settings. If you're already using TKIP, try AES.
    Samsung phones always have this issue with some routers.
    srkmagnus likes this.
    03-16-2016 08:55 PM
  10. Mooserman15's Avatar
    Your carrier deliberately slows down wifi to force you to use your data. Also GET RID OF YOUR COMCAST INTERNET. I HAVE COMCAST AS MY ISP, AND I PAY $600 PER MONTH FOR 0.0000000001 MBPS.
    03-16-2016 09:45 PM
  11. meyerweb#CB's Avatar
    I'm running about 20% faster download, and 30% faster upload compared to my G3, so it's not a problem with all S7s.
    03-16-2016 10:33 PM
  12. mpgrahn's Avatar
    WPA2 Personal
    About 6-7 months
    Same here, I turned off security and i get 90mbps on the S7 now. I was using WPA2 Personal..
    I have a WRT 1900 ACS router that I bought about 2 weeks ago. Once again my S4 gets 90mbps with security on. My S7 gets 20Mbps with security on.
    03-17-2016 09:07 AM
  13. mpgrahn's Avatar
    03-17-2016 09:18 AM
  14. mpgrahn's Avatar
    mode set is ac only.
    03-17-2016 09:28 AM
  15. Not Quite Right's Avatar
    That's not true. stop trolling ...
    03-17-2016 10:35 AM
  16. Not Quite Right's Avatar
    Anyone think it's a Marshmallow issue rather than a Samsung issue? Just throwing that out there ...
    03-17-2016 10:38 AM
  17. mpgrahn's Avatar
    for my situation, it appears how my S7 interacts with WPA2 on my router. My router is a Linksys WRT 1900 ACS.
    03-17-2016 10:59 AM
  18. mpgrahn's Avatar
    could very well be a Marshmallow issue.
    03-17-2016 01:35 PM
  19. Jerry Hildenbrand's Avatar
    It's a Samsung thing, sort of. It happens on their TVs, it happens on their laptops, it happens on their phones and tablets.
    But only with some routers. AES encryption makes for very slow wireless speeds. I have no idea why or how it happens, but i know you can switch the encryption method to fix it yourself, or wait for a firmware update on your router.
    The interesting part is that it's always the people building routers who need to fix it. Makes me think that Samsung is using the latest/best software for encryption and data transmission over 802.11, and the folks making some routers just fall behind.
    The bad part is that Samsung gets the blame when it's never them who need to fix the software. There's nothing wrong with your phones, it's your router.
    03-17-2016 04:55 PM
  20. Jelly Belly's Avatar
    Mine seems fine. First image is from the S7 and the 2nd image is to the same server from my hard wired Mac.
    I'd say at least in my case the S7 is wringing every bit of speed from the connection.
    03-17-2016 05:06 PM
  21. Rheller82's Avatar
    Is this only happening to the snapdrafon version? Maybe it's the chipset. It's happening on my att version.
    03-18-2016 05:52 AM
  22. johnny8410's Avatar
    Just wait until you can get Gigapower. Its awesome!
    I wasn't aware of that service. I just googled it but unfortunately it's not yet available in my area. Do you have it already? What speeds are you getting? Price?
    03-23-2016 10:34 PM
  23. clay123456's Avatar
    I have the same problem. 25mbps download when my internet is 150mbps. Brand new S7 from ATT. Router is linksys WRT1900AC. I think it's the router and not the device, like others have stated. I absolutely hate this router and have had endless problems with it. Problems with it dropping devices, needing to be reset way too often, slower speeds than it should have, trouble accessing network storage on usb3.0, etc, etc.
    I've had endless trouble with an Nvidia Shield TV and this router. Certain phones have a real hard time. I had to return a windows 10 laptop (XPS 13) because of wifi issues. It all comes back to the router. These routers are supposed to have excellent read/write speed on attached storage, yet in my experience it's only 3MB/s, which is much slower than what you would expect on AC 2x2. It works better when devices are hard-wired but that's not the point of AC 2x2 wifi.
    I'll try changing the router encryption type. Hopefully that will help. I'll report back.
    12-20-2016 11:08 AM
  24. clay123456's Avatar
    25mbps w/ WPA2 personal.
    35mpbs with WPA2/WPA Personal.
    150mbps with no security.
    Damn router. Thing is so annoying.
    12-20-2016 11:37 AM
  25. Dawhoda's Avatar
    You're on crack if you really think the s4 is faster than the s7 dude
    10-04-2017 09:37 AM
52 123
  1. Replies: 44
    Last Post: 08-09-2018, 02:01 AM
  2. Bluetooth issues with Regular S7
    By steelhand69 in forum Samsung Galaxy S7
    Last Post: 07-14-2016, 08:11 PM
  3. Can I remove the little house icon on my home screen?
    By nikoflame in forum Samsung Galaxy Note 5
    Last Post: 03-16-2016, 04:31 AM
  4. Can I remove the little house icon on my home screen?
    By nikoflame in forum General Help and How To
    Last Post: 03-15-2016, 03:04 PM
  5. Replies: 1
    Last Post: 03-15-2016, 02:58 PM
