View Poll Results: Does this happen on your s7 edge?
Voters
7. You may not vote on this poll
  • Yes
    1 14.29%
  • No
    6 85.71%
  1. shadow82x's Avatar
    Hi All -
    I notice a weird issue with my home button. Sometimes my home button fails to register a normal tap on the left-ish side. If I press down in the center, it works fine.
    Furthermore, if I hold down the home button towards the right side to launch google on-tap, it will launch, but if I use the same kind of pressure on the left, it doesn't launch. I really have to press down on the left side to launch it. Does anyone else experience this issue? Should I exchange it? If I were to guess around 14/15 home button clicks register.
    ETA - I just uploaded this video, you should be able to see the issue pretty clearly. (Sorry it's sideways.)
    03-15-2016 06:56 PM
  2. Dubss's Avatar
    Let me see if none does that
    shadow82x likes this.
    03-15-2016 07:55 PM
  3. dpham00's Avatar
    They should all register. If not then ask for a replacement
    03-15-2016 10:23 PM
  4. pinkvikchick's Avatar
    NOoooo no exchange it. I can press the very edge of mine with my nail (either side) and it registers. Don't deal with that!
    03-16-2016 09:46 AM
  5. shadow82x's Avatar
    Decided I'm going to return it. Just hope I don't get a non-uniform screen now, or some other issue. ugh.
    03-16-2016 02:01 PM
  1. How do I fix my home button?
    By jinglebelldjamel in forum Samsung Galaxy S6
    Last Post: 03-22-2016, 02:50 PM
  2. Can I remove the little house icon on my home screen?
    By nikoflame in forum Samsung Galaxy Note 5
    Last Post: 03-16-2016, 04:31 AM
  3. S7 Wifi is useless on home network
    Last Post: 03-15-2016, 07:02 PM
  4. "move to sd card" button grayed out
    Last Post: 03-15-2016, 03:09 PM
  5. Can I remove the little house icon on my home screen?
    By nikoflame in forum General Help and How To
    Last Post: 03-15-2016, 03:04 PM
