1. vferrari's Avatar
    Game Launcher was constantly prompting me as games were downloaded to my device. As I was trying to do the initial setup of the phone I declined the request to add apps to game launcher until I had the time to read the Samsoung terms. At some point along the way, Game Launcher completely disappeared from the phone. I did not uninstall it. Any ideas on how to get it back (short of a factory reset since I am not excited about the prospect of setting this phone up AGAIN). Any help would be appreciated.
    03-15-2016 08:23 PM
  2. LOD66's Avatar
    I have had my own issues with the launcher today,but in trying to fix it i noticed that if you open up settings, click search in top corner and search 'game' you should get one choice for game launcher. Click this and it should have a toggle button for turning game launcher on, and if you do it should add it to your home screen and app menu. Hope this helps
    xocomaox likes this.
    03-15-2016 11:13 PM
  3. vferrari's Avatar
    Thanks. That did the trick. Could not figure out where that obscure setting was located. I found game mode (not launcher) in the application manager but could not for the life of me figure out how to actvate it. I have never understood why android allows you to disable or force stop an app from within app manager but does not allow you to launch an app from app manager.
    03-16-2016 02:31 AM
  1. Apps Edge is much more useful than I've expected
    By ZeneticX in forum Samsung Galaxy S7 edge
    Last Post: 03-15-2016, 10:22 PM
  2. can't take lock off my samsung s5
    Last Post: 03-15-2016, 10:20 PM
  3. I can't get rid of the text signature in my Galaxy S5
    By Aicam_bip in forum General Help and How To
    Last Post: 03-15-2016, 09:34 PM
  4. How can I update from 4.0
    Last Post: 03-15-2016, 09:27 PM
  5. Replies: 0
    Last Post: 03-15-2016, 07:57 PM
