1. PsychDoc's Avatar
    I want to move it down toward the bottom of the screen. Right now it's about 2" from the top of the screen which is right where my thumb rests. I find I'm accidentally touching it when I don't want to. It would be much better towards the bottom of the screen but I can't seem to find any way to move it.
    Is there a way that I'm missing? I'm with Verizon if that's a factor.
    03-16-2016 11:49 AM
  2. anon(238680)'s Avatar
    The manual tells how to relocate it, but I can't remember how as the current location works fine for me so I paid no real attention to how to move it.
    03-16-2016 11:51 AM
  3. Lobwedgephil's Avatar
    In the edge panel settings, click on edge panel handle settings at the bottom and then you can select where to place on the side.
    03-16-2016 11:53 AM
  4. Adiliyo's Avatar
    from the edge panel settings you can also change the translucence of the tab (mine is transparent now)
    03-16-2016 12:06 PM
  5. Idelgado782's Avatar
    Thank you! Just purchased the note 7 and it's my first edge phone and it was driving me crazy! I thought Samsung didn't include the option to adjust it! This should definitely be on those lists and videos out there "10 hidden tricks and tips for the note 7"
    08-25-2016 04:51 PM
  1. Replies: 2
    Last Post: 03-19-2016, 10:25 PM
  2. Gmail Doesn't Work On S7 Edge
    By mango1228 in forum Samsung Galaxy S7 edge
    Last Post: 03-18-2016, 11:52 AM
  3. Which color is the most fingerprint magnet?
    By eak1570 in forum Samsung Galaxy S7 edge
    Last Post: 03-16-2016, 08:08 PM
  4. I have a note 2 and my yahoo mail takes forever to load.
    Last Post: 03-16-2016, 11:43 AM
