1. throttlehappy's Avatar
    How come there's no notification symbol at the top when location is on? My S5 always had one if it was turned on.
    03-16-2016 03:22 PM
  2. anon(238680)'s Avatar
    Mine has one, balloon with a hole in it. Also reported on lock screen notifications.
    03-16-2016 03:42 PM
  3. kahoon's Avatar
    I have no notification as well. Didn't realize it before this. Lol.
    03-16-2016 03:58 PM
  4. Adiliyo's Avatar
    it only shows when location is being actively used. it won't show if an app or the system isn't using the service at the moment.
    03-16-2016 04:01 PM
  5. throttlehappy's Avatar
    That sucks. I don't leave mine on all the time so I have to check and make sure it's off.
    03-16-2016 04:26 PM
  6. gnuser's Avatar
    No location symbol anymore. The new way of doing things.
    03-16-2016 04:39 PM
  7. Adiliyo's Avatar
    you can move it up in the quick settings list so you can see it when you pull the notification shade down.
    personally i like it this way since i always leave it on and don't need more icons cluttering up the bar.
    i wish i could get rid of the stupid AM/PM indicator and also the NFC icon.
    03-16-2016 05:57 PM
  8. throttlehappy's Avatar
    Yea, I have it moved up in the quick settings so I can see it by swiping down.
    03-16-2016 06:02 PM
  1. Camera symbol dissappears
    Last Post: 03-16-2016, 09:25 AM
  2. GOsms contacts location
    Last Post: 03-14-2016, 07:44 AM
  3. android green symbol showing downloading
    Last Post: 03-13-2016, 10:07 PM
  4. android green symbol showing downloading
    By AC Question in forum Samsung Galaxy S4 Mini
  5. Widget location?
    By scotchipman in forum Samsung Galaxy S7 edge
    Last Post: 03-12-2016, 07:16 PM
