1. gnuser's Avatar
    Have been noticing a text message sent to 94183571 every now and then...
    "GET?c=SAM:SM-G935A/6.0.1:1.0.24-6&v=1.0&l=myphone#&AD"
    I am sure it is related to a setting don't know what...
    03-16-2016 05:11 PM
  2. DuCeNuKeM's Avatar
    I'm also getting this. I Google'd the number but could not find any information.
    03-16-2016 05:15 PM
  3. gnuser's Avatar
    I think it is a network thing. Are you on ATT? Or some app trying to do this.
    03-16-2016 05:23 PM
  4. DuCeNuKeM's Avatar
    Yes I'm with at&t. The G935A is the AT&T model.
    03-16-2016 05:26 PM
  5. gnuser's Avatar
    Let's wait for other Androiders to reply
    Toni Fackler likes this.
    03-16-2016 05:38 PM
  6. GR0D's Avatar
    I had something similar like that when playing around with OnCircle but haven't gotten it again.
    03-16-2016 05:41 PM
  7. Gator352's Avatar
    I had this problem with sprint a while back. It is a network thing. I called sprint and had them reset (provision) my network data and have never had this problem again.
    KPMcClave likes this.
    03-16-2016 06:21 PM
  8. NAHurry's Avatar
    I believe I figured this out. My AT&T Galaxy S7 was doing the same thing, which is how I found this thread.
    If you parse the message, You will see it is sending the phone model, the Android version (6.0.1) and then another thing that looks like a version number. This happens to be exactly the same as the version of AT&T's Visual Voicemail app that was preloaded on our phones.
    It seems that when the phone reboots/restarts the Visual Voicemail app is trying to report something to AT&T. I had not opened the Visual Voicemail app since getting my phone last week, so what I did was open the app, and let it do it's setup routine. Now, when I reboot the phone, I no longer see these backend messages in my Messaging app. They may still be being sent, but I believe they are now being masked from view. I don't see them anymore. Try running the Visual Voicemail app and go through its set up process. It may stop these messages from being seen anymore.
    Mark Skarzynski and KPMcClave like this.
    04-01-2016 06:00 PM
  9. Mark Skarzynski's Avatar
    Thanks for the tip! I just got the latest OTA last night and saw this message this morning. It makes sense that the app is trying to phone home after an update.
    04-22-2016 09:29 AM
  10. KPMcClave's Avatar
    Every once in a while you'll get a similar type outgoing message from an app (other than VVM) trying to authenticate your phone when first installed. I can't recall specific examples, but I've definitely seen this sort of thing before...and was concerned, until I figured out where it originated.
    04-22-2016 10:34 AM
  11. Vera Simpson's Avatar
    The same thing just happened to me. But I looked at the time and realized that it was from the set up for my Visual Voicemail. Just glad it wasn't anything serious. Hope this helps.
    07-31-2017 12:13 AM
  12. Chris Levingston's Avatar
    Firmware file for android when you change carriers
    06-02-2018 11:21 AM
  13. swdaley_tech's Avatar
    GET?c=ATTV:Pixel XL/8.1.0:4.2.0.0046&v=1.0&l=cell#&AD I just this today. So it seems that the Att Visual Voicemail app still does this from time to time. I ended up removing the app as I don't use it all that much.
    06-23-2018 09:36 PM
  14. Young Ray's Avatar
    Im getting this as well. Im with kricket.
    07-09-2018 10:42 PM
  15. Young Ray's Avatar
    GET?c=ATTV:SAMSUNG-SM-J321AZ/6.0.1:3.2.0.100171&v=1.0&l=&AD
    Just took my my number out. Other than that im gettit this text i dint text.
    07-09-2018 10:44 PM
  16. Misha326's Avatar
    I'm sure you figured it out by now but Cricket is AT&T. I found this thread cause same thing happened and I am Cricket as well. But I just activated Cricket's visual voicemail and got this text so I'm sure that's where it came from. Glad I found this!
    03-12-2019 03:07 PM
  1. Replies: 2
    Last Post: 05-11-2016, 11:15 AM
  2. What is the release date for the LG G5?
    By AC Question in forum LG G5
    Last Post: 03-18-2016, 12:51 PM
  3. Accidentally bought an S7 Edge PLUS case.....Wait what!?
    By icellphones32 in forum Samsung Galaxy S7 edge
    Last Post: 03-17-2016, 02:18 AM
  4. Why is my Samsung S5 not recognizing my password/pin?
    By AC Question in forum Samsung Galaxy S5
    Last Post: 03-16-2016, 07:02 PM
  5. SD Card: I need help how to use this prop!
    Last Post: 03-16-2016, 03:16 PM
