1. power4rmor's Avatar
    Just curious about this one. When I change from silent to sound it never gives any sound at all unlike previous models. Like on my note 5 it makes a sound when I switch from silent to sound.
    Is it built to be quiet now?
    03-16-2016 05:15 PM
  2. dpham00's Avatar
    It is not there anymore
    03-16-2016 05:17 PM
  3. power4rmor's Avatar
    Thanks!
    03-16-2016 05:28 PM
  4. Adiliyo's Avatar
    mine makes a noise when i push the button....
    03-16-2016 05:55 PM
  5. power4rmor's Avatar
    When you pull it down from the notification panel?
    03-16-2016 06:01 PM
  6. lammy8's Avatar
    Mine makes the same noise as when you press the voice search function for Google
    03-16-2016 06:15 PM
  1. Is Samsung listening to all this???
    By gnuser in forum Samsung Galaxy S7 edge
    Last Post: 03-16-2016, 09:53 PM
  2. Replies: 2
    Last Post: 03-16-2016, 05:50 PM
  3. How do I block or stop the Eula software on a cell phone?
    Last Post: 03-16-2016, 05:48 PM
  4. How come my Smart switch app won't open?
    By AC Question in forum Samsung Galaxy S7
    Last Post: 03-16-2016, 05:46 PM
  5. Newbie wants to install a custom ROM, need some help
    By Caranthir in forum Samsung Galaxy S5 Rooting, ROMs & Hacks
    Last Post: 03-16-2016, 04:59 PM
