1. VetteVert's Avatar
    I probably missed it somewhere, but is there any way for Bluetooth volume to remain at max (or at its previous setting)? Currently it keeps jumping down to the middle and I have to acknowledge that high volume is detrimental to society at large.
    Thiscrapsucks35 likes this.
    03-16-2016 06:53 PM
  2. jls1986's Avatar
    Same here. My s5 did the same thing. Not sure if there's a way around it.
    03-16-2016 06:54 PM
  3. dpham00's Avatar
    Not without root.
    03-16-2016 07:25 PM
  4. edubb256's Avatar
    There are a few apps that do this without root. One is called Hearing Saver. Another is called Bluetooth Volume
    jls1986 likes this.
    03-16-2016 08:08 PM
  5. VetteVert's Avatar
    Hrm. I will check these out. Didn't need them with my old g2....
    03-16-2016 08:29 PM
  6. pinkvikchick's Avatar
    On the Note 5 and Edge 7 I've noticed that if I restart my phone, it goes back to this setting. Stays the same if I haven't reset.
    03-17-2016 09:43 AM
  7. DaveInFL's Avatar
    I have noticed this too. Annoying. Actually, on the S7e it seems that the Bluetooth volume is associated to the overall volume. My HTC One M8 had a separate volume for Bluetooth so that when I set it to max it stayed there...Was great, really miss that. I tend to have the phones volume quite low and when I get into my car I have to faff around to put the volume to its max setting.
    03-17-2016 09:54 AM
  8. edubb256's Avatar
    Yes it is very annoying the way Samsung implemented this.
    03-17-2016 11:31 AM
  1. Replies: 2
    Last Post: 05-11-2016, 10:15 AM
  2. Replies: 1
    Last Post: 04-17-2016, 07:01 PM
  3. Samsung Galaxy S6 Edge Bluetooth connectivity issue, how can I fix it?
    By dave_cunnah in forum Samsung Galaxy S6 edge
    Last Post: 03-17-2016, 06:43 PM
  4. Samsung Galaxy s6 edge Bluetooth connectivity issue
    By dave_cunnah in forum Ask a Question
    Last Post: 03-16-2016, 05:50 PM
  5. Bluetooth Phonebook Issue.
    By TzrNPeg in forum Verizon Galaxy S III
    Last Post: 03-16-2016, 01:31 PM
