1. Antony Guan's Avatar
    So when I was looking around the phone, I noticed that my sim tray wasn't flush or level with the side of my phone, like one side of the tray is more in the phone but I put a picture in here, but is anyone else having this issue of the sim tray not level with the phone and will it affect the waterproofing feature? Anyone having issues with the Sim tray?-20160316_231759.jpg
    03-17-2016 02:24 AM
  2. SpookDroid's Avatar
    Mine looks pretty flush... In theory everything 'open' in the phone is covered with hidrophobic nanocoating, so you should be OK. But if it bothers you, the sooner you get a warranty replacement the better chances you have of getting a new unit and not a refurb. On the other hand, due to high demand, it might take longer for you to actually get a replacement.
    You can try and take it to a store and ask them to let you try another Edge's tray in yours and viceversa. Kinda see if it's the tray or your phone's port.
    03-17-2016 05:16 AM
  3. dpham00's Avatar
    Mine is flush. I would certainly try what Spook said...
    03-17-2016 09:01 AM
  4. Antony Guan's Avatar
    I looked at a couple videos and it looked like some other peoples sim tray had a problem too. Anyone having issues with the Sim tray?-20160317_192417.jpg
    Attached Thumbnails Anyone having issues with the Sim tray?-screenshot_20160316-233732.jpg
    03-17-2016 10:23 PM
  1. What is the best custom ROM for me?
    By Mooserman15 in forum General Help and How To
    Last Post: 03-17-2016, 10:18 PM
  2. Does anyone know how to clear a pin number on an Xperia (Sony) E1?
    By AC Question in forum Sony Xperia Series
    Last Post: 03-17-2016, 04:34 PM
  3. How can I unlock my SIM card?
    Last Post: 03-17-2016, 05:16 AM
  4. Replies: 1
    Last Post: 03-17-2016, 02:40 AM
  5. Loading Launcher issue on Alcatel Onetouch
    By Ultimatedeathpuppy in forum Ask a Question
    Last Post: 03-17-2016, 01:09 AM
