1. Peter SGS7's Avatar
    Hello guys, I have a bit of an issue, I want to use the Smart Stay function on my galaxy S7 edge.
    The function is turned ON in settings, but I never get the eye symbol, that tells me that the function is tracking my eyes and working, on matter in what lightning conditions..
    Have Samsung removed this feature and smart scroll from the galaxy S7??
    Thanks for your help
    Posted via the Android Central App galaxy S7 Edge
    03-17-2016 09:47 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Is your front-facing camera blocked?
    03-17-2016 11:41 AM
  3. Peter SGS7's Avatar
    I don't think so, the front facing camera works perfect in selfie mode.
    Does the camera have to be separately activated for that purpose?
    03-17-2016 01:18 PM
  4. B. Diddy's Avatar
    I don't believe the front camera has to be separately activated. It's possible that some 3rd party app that has Camera permissions might be causing issues. Also, do you have any power saving modes turned on?
    03-17-2016 06:38 PM
  5. Peter SGS7's Avatar
    ****, it's beginning to sound complicated :-/ I have also tried both scenarios, but dosent seem to make a difference:-/
    03-17-2016 07:03 PM
  6. B. Diddy's Avatar
    A quick and easy way to determine if some 3rd party app is causing the interference is to boot into Safe Mode: https://support.t-mobile.com/docs/DOC-24977. If the problem goes away in Safe Mode, then you know something you installed is the culprit. The tricky part is figuring out which app.
    03-18-2016 11:42 AM
  7. Peter SGS7's Avatar
    Ok great! I will try it tonight, hope it works.
    03-18-2016 11:46 AM
  8. jem9777's Avatar
    Smart Stay works on mine. I can be looking at the screen and it stays on well in excess of my timeout setting, but as far as I can tell they have removed the eye icon - I have never seen it on the S7. Also didn't have the eye icon on my Galaxy S6 or Galaxy Tab S2.
    B. Diddy likes this.
    03-18-2016 08:41 PM
  9. Peter SGS7's Avatar
    Ok that interesting to know. But then what about the Smart Scroll?
    03-19-2016 09:45 AM
  10. t11rmh's Avatar
    I've had smart stay enabled since S4 days and it has never worked for me. Tried it on my s7 Edge and it still doesn't work. Total waste for me.
    Posted via the Android Central App via a kicking Gold Galaxy S7 Edge.
    03-19-2016 03:10 PM
  11. Peter SGS7's Avatar
    Okay then, I was starting to wonder if there was something wrong with my Samsung. Buy it seams like a general problem.
    03-19-2016 03:31 PM
  1. Paint on home button is peeling. Anyone else have this issue?
    By santims in forum Samsung Galaxy S7 edge
    Last Post: 01-19-2017, 06:15 PM
  2. Replies: 3
    Last Post: 03-18-2016, 10:51 AM
  3. Issues with G5308W
    By cwyeo85 in forum Samsung Galaxy Grand
    Last Post: 03-18-2016, 01:46 AM
  4. Chrome on I pad vs Android issues
    By AC Question in forum Chrome
    Last Post: 03-17-2016, 08:26 AM
