1. sauron4's Avatar
    Hi guys,
    I'm new to Android so haven't got a clue on how to backup the whole of my device, I would like it so that when I receive the replacement of my S7 Edge I can just restore the device and have minimal setting up on the new device.
    Is there a way to do this within Android or do I need to use an app and if so which is the best app for this?
    Thanks
    03-17-2016 11:32 AM
  2. dpham00's Avatar
    You can use the smart switch app
    03-17-2016 11:34 AM
  3. DuCeNuKeM's Avatar
    Use smart switch. It can be found in backup and reset
    03-17-2016 11:36 AM
  4. sauron4's Avatar
    With Smart Switch do I need to have both devices to do this? As I will be doing a door to door swap.
    03-17-2016 11:39 AM
  5. DuCeNuKeM's Avatar
    You can download the smart switch application in your windows pc. Then backup your stuff to that and restore from there when you get your new Samsung phone.
    sauron4 likes this.
    03-17-2016 11:42 AM
  6. DuCeNuKeM's Avatar
    You can also have smart switch on both phones and do it that way through nfc/Bluetooth.
    smart switch is available in the play store.
    sauron4 likes this.
    03-17-2016 11:43 AM
  7. sauron4's Avatar
    Oh awesome! I shall try that out later tonight then and see how I get on.
    Thanks for your help
    DuCeNuKeM likes this.
    03-17-2016 11:44 AM
  1. Replies: 0
    Last Post: 03-17-2016, 11:25 AM
  2. Samsung S6 not connecting to Android Auto - VW App-Connect
    Last Post: 03-17-2016, 11:23 AM
  3. Replies: 1
    Last Post: 03-17-2016, 11:20 AM
  4. Can I reset my phone
    Last Post: 03-17-2016, 11:16 AM
  5. Phone and/or Battery problem
