04-13-2017 04:20 AM
62 123
tools
  1. Corbean's Avatar
    09-27-2016 01:33 AM
  2. Mojopa613's Avatar
    I having issues with my SD Card - the software informs me that "MADE IN VIETNAM 22.02.2016
    I am not sure if this is related but laley my phone has been freezing and hanging on a regularly bases.
    I have the same problem when I enter my SD card the phone freezes. And my phone is also made in Vietnam. How did u solve that problem?
    10-12-2016 06:10 PM
  3. superglue7's Avatar
    Same here - after inserting SD into my brand new phone it became unstable. Even had to hard reboot by pressing sound down + power buttons.
    My SD card is SanDisk Ultra 32GB. It was working perfectly on my S5. My failing S7 edge is manufactured in Vietnam on 04/13/2016.
    Besides my car is unable to import contacts from S7. S5 had no problems. Already thinking to go back to S5 and to have peace of mind.
    11-04-2016 12:06 PM
  4. Alanhd's Avatar
    Did you format the card in the phone after you put it in?
    11-07-2016 02:46 AM
  5. chanchan05's Avatar
    Ideally you format the card in the new phone you use it in. Does not matter if it was working perfectly before. You're transferring data from an older version of Android. You need ti start fresh.
    11-07-2016 03:32 AM
  6. TrafficKelly's Avatar
    I have had my phone replaced 2 times due to this issue, all 3 of the phones had issues with sd card randomly not reading it's a right pain.
    I have now fixed my issue, what was causing it was a think sim card that was allowing movement to the sd card, to fix this I have rubbed down the sim card and added a small part of tape around the mid of the sd card. Not ideal on a phone made in 2016 but with innovation comes flaws am sure Samsung will sort this in future designs.
    So glad it wasn't my 200GB sd at fault.
    Oh mine was 11/03/16 Vietnam
    Cheers
    Brian
    11-13-2016 03:11 AM
  7. tadpoles's Avatar
    Cheers
    Brian
    You're very forgiving.
    11-15-2016 01:04 PM
  8. VipinLJ's Avatar
    Hey guys
    My phone has the exact same problem.
    So I got my first phone (Samsung galaxy S7 edge, 32gb) from T-mobile in June. I used to get the error message and an update prevented the error message from popping up but my memory card would keep getting "corrupted" and then after a few weeks, it would be fine. It happened three times and I let it be (twice it started working by itself and another time, I had to remove the card and reseat it). The fourth time it happened, I took it to T-mobile (on 11/26/2016). The manager there checked out the phone and the card and determined it was the phone (phone was made in Vietnam). He put in a warranty replacement and got me a new phone which I got last night.
    I put in the same sd card I used in the old phone (Sandisk, 64gb), formatted it, transferred pictures onto it and it worked fine). Today morning, less than 24 hrs later, the same trouble has started. The pictures appeared as a broken file in the gallery and then, in restarting my phone, it disappeared from my gallery. SD card works fine though (I put it in another phone (HTC One E8) and everything appears fine on that phone.). I downloaded phone info and this phone is also made in Vietnam (date 2016.03.14). This issue is beginning to get in my nerves now. The phone is fully paid off for and I can't seem to get them to get me an iPhone even if I'm willing to pay extra.
    Any help guys? What do you suggest?
    Regards,
    Vipin
    12-01-2016 09:09 AM
  9. MannMadeMedia's Avatar
    It's the 3rd time my S7 has decided the SD card is unsupported / corrupted it.
    This time, I've just run an android update and it immediately corrupted the card.
    I've been to the Samsung store twice before and both times they said it was probably the card. This is the 3rd Samsung card, it is only 2 weeks old.
    Obviously there is something wrong with either the phone or the software NOT the card.
    01-02-2017 04:25 AM
  10. rednroll's Avatar
    "Go to Apps -> Settings -> Display and turn Smart stay off. Restart the S7/S7 Edge."
    Mine was never turned on.
    I've been having this same problem with my S7 Edge where it seems the card often disappears. If I go to the "My Files" browser app, the SD card is available but it shows no files.
    I've tried re-formatting the card in the phone but that didn't help, same problem after format.
    The way that I'm able to fix this problem, is to just restart the phone and then the card and all my files on it starts working again. Then it seems the next time I need to access the card for photos or music, it's gone again. So I don't believe the card tray is the problem because if I reboot the phone without touching the card, then why would the card and files show back up after reboot?
    This is frustrating, I bought this phone over an iPhone for one reason.....it had an SD Card slot!!!!
    jhimmel likes this.
    02-17-2017 03:13 PM
  11. Tachead7075's Avatar
    My S7 Edge has no problems like this whatsoever. I have never had an SD card issue since I got my phone with two different SD cards and hundreds of gigs of pictures, videos, files, etc.
    Where are you guys buying your SD cards? Could they be fakes? Have you ran SD Insight to confirm they are authentic? This is a common issue in the SD card industry.
    B. Diddy likes this.
    02-17-2017 03:25 PM
  12. Andy Kristian's Avatar
    i have common problem here, and i just tried "Go to Apps -> Settings -> Display and turn Smart stay off. Restart the S7/S7 Edge." (bcoz my smart stay is ON) and it seem work so far(around 15min after restart).
    i tried to find SD Insight to check my sd card is fake or not in the playstore but it says "your device isn't compatible with this version." any suggestions?
    04-13-2017 04:20 AM
62 123
  1. Gear VR not working on 7 edge
    By drinking12many in forum VR Headsets
    Last Post: 05-07-2017, 01:25 PM
  2. My sister the luddite, and her Galaxy S7 by Russell Holly
    By Assassin Droid in forum Samsung Galaxy S7
    Last Post: 03-21-2016, 12:55 PM
  3. (Wireless charging) - Can I overcharge my S7 Edge?
    By KahneFan in forum Samsung Galaxy S7 edge
    Last Post: 03-18-2016, 09:03 PM
  4. Galaxy S6 resetting background?
    By BoneDigger in forum Samsung Galaxy S6
    Last Post: 03-18-2016, 08:45 AM
  5. Replies: 0
    Last Post: 03-17-2016, 12:41 PM
