1. wisewhisk's Avatar
    Hi everyone,
    I've been using the Samsung Fast Charge Wireless Puck to charge my phone every night before bed. When I wake up, I've noticed that the phone is still warm. I would think that once it reaches 100% capacity, it would stop charging and cool down. When I use the USB fast charger that came with the phone, it's not warm at all in the morning.
    I think I've read that heat is generally bad for the battery life. Does anyone else have the same issue? Should I only use the Fast Charging puck when I need a quick charge?
    Thanks.
    03-17-2016 09:01 PM
  2. brava27's Avatar
    Don't sweat it. It's normal
    03-17-2016 09:03 PM
  3. wxman2003's Avatar
    Turn off fast wireless charge if you charge when you go to bed. No need to fast charge if the phone sits on the charger for 7 to 8 hours. Turn off fast charge on the phone, and you can still use the fast charge puck. It just won't fast charge.
    LanceAllan likes this.
    03-17-2016 09:21 PM
  1. How to check which Samsung SM-G935F (S7 Edge) variant I have?
    By King Mustard in forum General Help and How To
    Last Post: 03-18-2016, 04:59 PM
  2. My samsung galaxy s4 sms is not working?
    Last Post: 03-17-2016, 09:07 PM
  3. Replies: 0
    Last Post: 03-17-2016, 08:54 PM
  4. How do i change the keyboard on a Samsung Galaxy s6 phone.
    Last Post: 03-17-2016, 08:51 PM
  5. My samsung galaxy s4 sms is not working?
    Last Post: 03-17-2016, 06:47 PM
