How high is everybodies average "android system" in the battery settings ?
Try turning your location settings from high accuracy (GPS, WiFi, and mobile data) to low power (WiFi and mobile data estimate of location) I just tried that a few minutes ago hopefully that helps a lot also change your WiFi and Bluetooth setting those also put a strain on your battery
Personally I'm okay with my stats. Fast charging / wireless charging solve any worry for me.
I use the high location a lot for GPS, weather, and also smart lock. That way it works how I expect.
Whats your usual SOT when you have your location turned on to high acc?
-S7Edge
Final before charging this morning.
I am having massive drain from cell standby (48%). By the looks of the screenshots you posted and others no one even has cell standby in their list. Do you have hd voice on? I don't know why this is happening but it is killing my battery.
I am on Verizon. I have wifi calling off. I don't understand why my cell standby is at 48% that is crazyYeah I use HD voice / VoLTE. I am on T-Mobile .. are you? If so, do you use WiFi calling?
I'd appreciate it, I have posted elsewhere and haven't received any feedback yet so I thank you for helping outThat is odd. Let me have one of our Verizon guys on the team come in and see if he is getting that on his S7 Edge.
Tell me about it, it's ridiculous. See belowThis is what I am seeing on Verizon.
Cell standby 48% seems high, unless you were idling most of the time
//uploads.tapatalk-cdn.com/20160318/8579fdf40e45b79f5735833ce40edf5e.jpg
Hm.. I wonder if you're seeing it since you're on wifi. dpham doesn't go on wifi much so that may be why he isn't seeing it.
